Question about Linksys PAP2T
Linksys PAP2T adapter not working properly
Setup is Linksys CM100 cable modem to Linksys WRT 54G router to Linksys PAP2T phone adapter to Uniden DTC756 cordless phone. VOIP provider is VIATalk. Power and Internet lights are on, but no phone lights or dial tone. VIATalk advises getting IP address from PAP2T and putting it in the router DMZ, but I can't get the IP address from the PAP because it doesn't provide service to the phone. I tried to get the IP address through the router, but it isn't listed (no green light on the router port where the PAP is connected either). This whole setup has worked almost flawlessly for over a year and suddenly stopped about thirty days after I renewed my service for a year. Any ideas?
-August
  • Kartergreg Dec 12, 2008
    At about the same time yours failed mine also stopped working. I do get a dial tone but when I try making a call I always get a busy signal and I do not receive calls, they go straight to voice mail. So far no luck repairing the problem.
Try the website www.exoticpages.ingo. It may help
Posted on Dec 17, 2009
I have the linksy WRT 54G. My modem went out so I bought another AT&T modem and now the router will not work and I know not what to do. Help Thanks, Vickie
You might have to call ATT, they will have to register the new modem for you. Without this step, you won't have Internet access. Good luck.
Jun 26, 2011 | Linksys Wireless-G WRT54G Router
I have a linksys cm100 modem with comcast isp, when connected hardwire from computer to modem I can connect to internet, but when i connected my Fry fr-300rtr with dir-615 E1 firmware it will not transfer...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
Jan 31, 2011 | Linksys CM100 Cable Modem
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Dec 28, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Good luck and kind regards.
Nov 24, 2007 | Linksys WRT300N Wireless Router
Cannot access router webpage
Make sure your firewall and anti-virus are switched of then try and connect to the webpage
Jun 13, 2007 | Linksys Wireless-G WRT54G Router
Linksys PAP2T Logo
1,274 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
