Question about Harman Kardon HK 3375 Receiver
Haron Kardon 3375 Recevier Shut Down Problems
My receiver has recently been shutting down...starts up for a few seconds and then shuts down. I've checked to make sure none of my speaker wires are shorted out...everything else looks OK. My wife claims something smelled when it went out. Any ideas?
  • cfbd May 11, 2010
    I The solution was a possibly blown 5 amp slow blow fuse. Where can a replacement be obtained? Can you tell by looking at a fuse if it is blown -- what will it look like? Thanks
5 amp "slow blow" fuse where power cord connects to amplifier has probably blown. 9 screws holds the cover on, remove them and check fuse.
Posted on Dec 09, 2007
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Ge front loader dcvh515efoww - dryer shuts off when put on heating cycle
Did you pull the dryer out or forward sounds like you may have pinched the exhaust which restricts air flow exiting the unit this will cause it to heat briefly shut down heat shut down and continue this cycle the fact that it worked before makes me think it something simple it will not tumble in any cycle if door switch not installed correctly.
Mar 21, 2014 | GE Dryers
Harman kardon avr 3550hd
If the display comes on for a few seconds (maybe 2-5?) and then shuts down it is likely a shorted output transistor(s) to start and possibly other bad components which would need to be replaced.
Aug 03, 2013 | Audio Players & Recorders
Engine shut after ten seconds
weak fuel pump witch is the sending unit or clogged fuel filter pin hole in the line some where bad throtle body
Jul 04, 2013 | 2006 Honda Odyssey
WINDOW XP WOM'T SHUT DOWN
Hold the power button in for a few seconds it will shut down. Then unplug system and push the power button down with it unplugged then replug it in and power up again. Then do a proper shut down again to see if the problem fixed. I hope this assisted you. John
Feb 07, 2011 | Microsoft Windows XP Professional
I have a Harman Kardon HK-3375 stereo receiver. I
A power switch either works or does not work. It does not power on and then mysteriously power off like yours is doing.
You have some sort of power relay that is being powered off after a few seconds.
I would check out the power supply for your anomaly. And no, it is not a simple fix like you are capable of performing.
Apr 01, 2017 | Harman Kardon HK 3375 Receiver
Receiver keeps shutting off after 3 seconds. what
Be sure the face is secure, and there is no dirt in the connection on the face, and head unit.
Sha'ul
Jun 27, 2009 | Harman Kardon AVR 120 Receiver
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
Harmon kardon avr 125 shuts down
If you want to fix it:
It must be a contact problem arount the power switch, power cable, fuse or the condensator area.
Maybe you can se a black color on the board.
And checking the solderind points with a magnifyer can help too.
Thats all from that distence.
Nov 11, 2007 | Harman Kardon AVR 130 Receiver
Harman Kardon HK 3375 Receiver Logo
380 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
