I have a Daytek LCD TV, which worked fine for a couple of years. Now there are problems with any bright white on the screen, for example views of golf that include sky, or commercials with white in them. The white on the screen jaggs out across the screen and the speakers emit an intensely loud and sharp buzzing sound. I've tried various settings with brightness and contrast, which lessens the effects slightly, but the problem is getting worse by the day.
  • kmcritch Nov 20, 2008
    Hello dopey19_89,
    You said: "Its sounds to be that the picture tube is (flaring) going bad you need to take it to or have a repair personal check it out."
    The above advice is posted under your heading: "Generic problem for all Projection Televisions."
    My TV does not have picture tube. Nor is it a projection television. As I mentioned in my query, I need a solution for my Daytek LCD (flat panel) TV. What can I do to fix the problem besides taking it to repair personnel?
    kmcritch
    Genius:
  • 1,550 Answers
The buzzing sound is coming from the yoke coils.
You need to replace it .
Posted on Nov 19, 2008
  • 147 Answers
Maxent 58" PLasma TV Model MX-58HPT51 screen flickers when it needs to display bright/white scenes. When i goto menu options, and LOWER the BRIGHTNESS setting, the flicker goes away. TV performs fine other...
It is a main power supply regulator board problem. Contact any service technician. In most cases, this board might need replacement as card basis.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 27, 2014 | Maxent MX-42XM11 Television
SAMSUNG LCD TV very bright screen
hi Elle924.
this is all i could find out.
What kind of panel do you have - a LED or CCFL one? If it's CCFL then check the inverter board. The main board might be fine (changing the brightness settings changes the signal to the inverter board) but if the inverter board is faulty somewhere then the problem you described may be caused by it
or try this forum.
Why is my tv extremely bright Solved Other Consumer Electronics
or this one might help you.
White too bright in picture on Samsung LCD TV Forums
or even this link.
SAMSUNG LCD TV very bright screen Google Search
Nov 28, 2017 | Televison & Video
LCD screen and small viewfinder screen go snowy than white. When I turn the camera on the LCD worked fine, when I than turn it, it was just white. Now it won't even turn on normal. I can still make...
Go to your menus, set all to factory settings or default.
Test the camera by using more of the settings, and notice how it works.
The LCD settings especially are what you want to make sure are set right...not too bright, and of course not too dim either.
Sep 25, 2009 | Canon Cameras
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
May 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
SAMSUNG LCD TV FAULT
samsung lcd tv 40inch modle .LA 40c 53F1R negitve video and brightness high plz send id mirzarashidbaig126@yahoo.com
Dec 12, 2008 | Televison & Video
TOSHIBA 42PW23P rear projection television
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2008 | Toshiba TP43H95 43" Rear Projection...
Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Televison & Video Logo
Top Televison & Video Experts
