There is a document pending printing and I have tried to cancel it for three days and I can't print anything else until that document is gone
  • 104 Answers
Here is a posting which may solve your problem:
http://www.fixya.com/support/t202855-job_in_queue
This is not my solution but BARRET's.... I hope it helps you.
Posted on Nov 19, 2008
  • 3 Answers
This solution worked perfectly, although I did have to reboot between the run command:
Start>>Run>>net stop spooler>>OK
reboot
Start>>Run>>net start spooler>>OK
Posted on Mar 22, 2009
My printer will not print. When you check the status of the document it says printing. When you cancel that it doesn't cancel. DAYS later the document prints all by itself. What's that about?
It's because the print queue is saved on the printer's flash memory. This happens when you don't cancel the queues properly or terminated improperly. To get rid of the issue, always try to give the command slowly and don't over load. If you are printing photos, try to make the file size small so that it'll not take long to spool and prepare for printing.
When the problem occurs, so as follows:
Cancel the queues from the print status box ("Cancel all documents"), if they are not cancelled, then turn off the printer (directly unplug the power cord from the printer), it you still see the printing status, keep on cancelling until everything's gone.
If the problem persists, restart your computer. Definitely the problem will be fixed.
It's also important to press the cancel button while the printer powers On.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | HP Officejet 5510 All-In-One Thermal...
Everytime I try to cancel the pending document it doesn't do anything just stays the same, so that does not allow me to print anything else because for some reason that pending doc. won't erase... please...
first do a right clickon the printer icon
select run as administrator if there or else try cancelling the document
if still does not work
go to run and type "services.msc" and it will take you to the services page
in the services page look for a service "print spooler "
restart the print spooler
and then try deleting the documents .......................... hope this should work for you let us know wat happens and we will help you accordingly ......take care ............god bless you ...........thank you (HAMID)
Oct 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
How can I cancel pending printing with my HP Deskjet D 1455?
You need to go to 'Printers' in Windows, and click on the document in the window to highlight it. Then one of the menu items gives you the option of deleting it.
Turning the machine off does not stop it because the print is held in Windows until the printer says 'thanks, done that', and if Windows senses that the print sequence has failed it simply tries again - and this happens, of course, when you turn the printer off and on again. Werry irritating.
Jun 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Having problems deleting pending documents
Assuming you have a modern windows pc, You will need to manually stop the print service. Do this by running the command "net stop spooler" from the "run" line. Then go to "C:\WINDOWS\System32\spool\PRINTERS" and delete all the files from there. After these files are gone, start the spooler service again by running "net start spooler". You should be all set after that.
Jun 09, 2009 | Office Equipment & Supplies
Wont let me cancel a pending document
I used to have the same issue. It happened on five different occasions. I tired all kinds of steps to fix it and none worked. Finally, my daughter fixed it for me by accident. She tripped over the plug to the computer. After it restarted, I canceled the document, and it worked perfectly. After that, i knew what to do. Hope this helps@
May 27, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP 1100 won't print after power outage during printing
Not worth it to fix. You can find 1100's on ebay for $30.
Mar 02, 2009 | HP LaserJet 1100 Printer
Printer wont print
open up the printer folder in your computer and then cancel the pending documents after that open SERVICES.MSC that u can easily find searching in your computer and after that look for print spooler restert that service 3-4 times and then restart your computer after that try and print if this oes not help leave a message i have a solution for that as well
Dec 31, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Printer is pending
the print spooler is not letting it print cancel the pending jobs you will be able to print fine keep on cancelling the documents unless the icon shows 0 document pending ....
Dec 16, 2008 | HP Deskjet D2430 Printer
862 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
