Question about Panasonic TX-42PT10 42" TV
Screen discolour screen showing two reddish smears approx 5 inch diameter
  • moegiovi Jan 03, 2008
    I had exactly the same thing happen to my 52 inch panasonic, good thing I purchased the extra insurance ,they told me it would not be economical to repair so they replaced it,,, after 5 weeks hope this will help someone...
  • 81 Answers
Sounds like a burn spot on one of the tubes open up to get access to the tubes and cover each one individually to determine which one and replace
Posted on Dec 13, 2006
SOURCE:
Ihave 2 sony xs-gtx120Lw 12' going in a 04 honda civic. I want to build a box but do not have the specs for them subs in a ported box
here are the specs
  • Depth (Approx.) : 5 3/4"
  • Diameter (Approx.) : 12"
  • Dimensions (Approx) Depth : 5 3/4"
  • Mounting Dimensions (Approx.) : 13" OD, 5 3/4" mounting depth and 11" mounting diameter.
  • Weight (Approx.) : 11 lbs. 11 oz.
  • Power Handling Capacity : 1000 Watts Max
  • Rated Input : 300 Watts
  • Magnet : Ferrite
  • Material : Polypropylene cone
  • Frequency Response : 30 - 1000 Hz
  • Impedance : 4 Ohms
  • Sensitivity (db) : 86 +/-2dB (1W, 1m)
  • Jun 03, 2011 | Car Audio & Video
    What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
    General Specifications Item Specification
    Displacement L (CID) 4.6 (281)
    Number of Cylinders 8
    Bore and Stroke mm 90.2 x 90.0
    Firing Order 1-3-7-2-6-5-4-8
    Oil Pressure (HOT @ 1500 rpm) kPa 138-310
    Drive Belt Tension a
    Cylinder Head and Valve Train
    Combustion Chamber Volume cm 52?±.5
    Valve Seats Width?€"Intake mm 1.9-2.1
    Valve Seats Width?€"Exhaust mm 1.9-2.1
    Valve Seats Angle 44.51-45.01 degrees
    Valve Seats Runout (T.I.R.) Max mm 0.025
    Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
    (Right Hand)
    I-E-I-E-I-E-I-E
    Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
    (0.00078-0.00272)
    Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
    Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
    Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
    Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
    (1.67 and 1.26)
    Valve Face Runout Limit mm (Inch) 0.05 (0.002)
    Valve Face Angle 45.25-45.75 degrees
    Valve Stem Diameter (STD)
    ?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
    Valve Stem Diameter (Std)
    ?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
    Valve Springs?€"
    Compression Pressure N @
    Spec. Length?€"Intake 587.14 N @ 28.02 mm
    Valve Springs?€"
    Spec. Length?€"Exhaust 587.14 N @
    28.02 mm
    Valve Springs?€"Free
    Length ( Approximate)?€"
    Intake mm (Inch) 49.55 (1.951)
    Length (Approximate)?€"
    Exhaust mm (Inch) 49.55 (1.951)
    Valve Springs?€"Installed
    Pressure N @ Spec. Length
    ?€"Intake 244.64 N @ 40.0 mm
    Valve Spring?€"Installed
    ?€"Exhaust 244.64 N @ 40.0 mm
    ?€"Service Limit 10 % Pressure Less @ 28.02 mm
    ?€"Out of Square Limit 2 degrees
    Valve Guide Inner
    Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
    Rocker Arm?€"Ratio 1.75:1
    Valve Tappet?€"Diameter
    (STD) mm (Inch) 16.000-15.988 (0.66-0.629)
    Valve Tappet?€"Clearance
    to Bore mm (Inch) 0.018-0.069
    (0.00071-0.00272)
    Valve Tappet?€"Service
    Limit mm (Inch) 0.016 (0.00063)
    Valve Tappet?€"Hydraulic
    Leakdown Rate b 5-25 seconds
    Valve Tappet?€"Collapsed
    Valve Tappet Gap?€"
    Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
    Camshaft
    Lobe Lift?€"Intake
    mm (Inch) 6.58939 (0.2594)
    Lobe Lift?€"Exhaust
    Lobe Lift?€"Allowable
    Lobe Lift Loss mm (Inch) 0 (0)
    Theoretical Valve Lift @
    Zero Lash?€"Intake
    mm (Inch) 12.0 (0.472)
    Zero Lash?€"Exhaust
    End Play mm (Inch) 0.025-0.165
    (0.00098-0.0065)
    Journal to Bearing
    Clearance mm (Inch) 0.025-0.076
    (0.00098-0.003
    Journal to Bearing
    Clearance?€"Service Limit
    mm (Inch) 0.021 (0.0048)
    Journal Diameter (All)
    mm (Inch) 26.962-26.936
    (1.061-1.060)
    Journal Diameter (All)?€"
    Bearing Inside Diameter
    (All) mm (Inch) 27.012-26.987
    (1.063-1.0625)
    Camshaft Runout
    Cylinder Bore
    Diameter?€"Surface Finish
    (RMS) 0.2-0.6 Microns
    Diameter?€"Out-of-Round
    Limit mm (Inch) 0.015 (0.0006)
    Service Limit mm (Inch) 0.020 (0.00079)
    Diameter?€"Taper Service
    Limit mm (Inch) 0.006 (0.00023)
    Piston
    Piston?€"Diameter?€"
    Coded Red 1 mm (Inch) 90.177-90.197
    (3.550-3.551)
    Coded Blue 2 mm (Inch) 90.190-90.210
    (3.5507-3.5515)
    Coded Yellow 3 mm (Inch) 90.203-90.223
    (3.513-3.5521)
    Piston-to-Bore-Clearance
    mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
    Pin Bore Diameter
    mm (Inch) 22.0015-22.004
    (0.866-0.8663)
    Ring Groove Width?€"
    Compression (Top)
    mm (Inch) 1.520-1.550 (0.06-0.610)
    Compression (Bottom)
    mm (Inch) 1.520-1.530 (0.060-0.0602)
    Ring Groove Width?€"Oil
    Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
    Piston Pin?€"Length
    mm (Inch) 61.93-62.05 (2.44-2.443)
    Diameter mm (Inch) 21.994-21.999
    (0.866-0.8661)
    Pin to Piston Clearance
    mm (Inch) 0.005-0.010
    (0.0002-0.0004)
    Pin to Rod Clearance
    mm (Inch) 0.015-0.040
    (0.0006-0.00157)
    Piston Rings?€"Ring Gap
    ?€"Compression (Top)
    mm (Inch) 1.0 MAX (0.0394)
    Oil Ring?€"Side Clearance
    mm (Inch) 1.25 MAX (0.05)
    Oil Ring?€"Compression
    (Top) mm (Inch) 0.040-0.090
    (0.0016-0.0031)
    (Top) mm (Inch) 0.030-0.080
    (0.0012-0.00031)
    Oil Ring Snug Fit
    Oil Ring?€"Service Limit
    mm (Inch) 0.015 MAX (0.0006)
    Ring Gap?€"Compression
    (Top) mm (Inch) 0.23-0.49
    (0.01-0.02)
    (Bottom) mm (Inch) 0.23-0.49
    (0.01-0.02)
    Ring Gap?€"Oil Ring (Steel
    Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
    Lubrication System
    Oil Capacity?€"Automatic
    Transmission (Quarts U.S.) 6.675?±0.125
    Oil Capacity?€"Manual
    Transmission (Quarts U.S.) 6.425?±0.125
    Cylinder Block
    Main Bearing Bore
    Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
    Crankshaft and Flywheel
    Main Bearing Journal
    Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
    Connecting Rod Journal?€"
    Diameter mm (Inch) 52.988-53.003
    (2.0861-2.0867)
    Crankshaft Free End Play
    mm (Inch) 0.130-0.301 (0.0051-0.012)
    Crankshaft Runout to Rear
    Face of Block mm (Inch) 0.050 MAX (0.002)
    Connecting Rod Bearings
    Clearance to Crankshaft?€"
    Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
    Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
    Bearing Wall Thickness
    (STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
    Main Bearings
    Desired mm (Inch) 0027-0.065
    (0.0011-0.0026)
    Allowable mm (Inch) 0.027-0.065
    (0.0011-0.0026)
    (STD) mm (Inch) 1.920-1.928 (0.075-0.076)
    Connecting Rod, Piston and Rings
    Connecting Rod?€"Piston
    Pin Bore Diameter
    mm (Inch) 21.959-21.979
    (0.864-0.865)
    Connecting Rod?€"
    Crankshaft Bearing Bore
    Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
    Connecting Rod?€"Length
    (Center-to-Center)
    mm (Inch) 150.7 (5.93)
    Alignment (Bore-to-Bore
    Max. Diff.) c ?€"Twist
    mm (Inch) 0.050 per 25 (0.0015-0.984)
    Max. Diff.)?€"Bend
    mm (Inch) 0.038 per 25 (0.0015-0.984)
    Side Clearance (Assembled
    to Crank)?€"Standard
    mm (Inch) 0.015-0.45 (0.0006-0.0177)
    to Crank)?€"Service Limit
    mm (Inch) 0.05 MAX (0.02)
    Crankshaft Main Bearing
    Journal Taper mm (Inch) 0.020 (0.0007)
    Journal Runout mm (Inch) 0.05 (0.002)
    Crankshaft Connecting Rod
    Journal Taper mm (Inch) 0.015 (0.0006)
    Feb 15, 2011 | 1998 Ford F150 Regular Cab
    I have a 1995 mercury mystique and can't find the starter
    The starter will be on the under side of the vehicle, on the engine. Look tor the component that is cylindrical shaped and has at least two wires going to it (one large approx 6 gauge and one small, approx 18 gauge). It will be 6-10 inches long and 3-5 inches in diameter.
    The starter can also be located by finding the red wire on the battery and tracing it under the car where it connects to the starter.
    Jul 26, 2009 | Mercury Mystique Cars & Trucks
    Black transparent smear on screen
    what kind of tv is it and is it a plasma?
    Apr 03, 2009 | Mitsubishi WD-65731 65" HDTV
    Shadows on screen
    Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
    Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
    Brother MFC9600 dirty printing
    We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
    Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
    Screen discolour
    to determine it is a tube cover one at a time when the reddish dots are there. if they dissappear when one of the tubes is covered it is the tube but other wise U have a bad chip
    Dec 13, 2006 | Panasonic TX-42PT10 42" TV
    Panasonic TX-42PT10 42" TV Logo
    64 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
