Question about Insignia LCDTV26 26 in. Television
How do I adjust the picture to fill the screen
I have a 50" plasma. I recently had a replacement HD satelite box replaced and I don't know how to get the full screen picture back.
I was having problems in the tv menu getting full screen. no matter what i did there was two black bars on each side of the screen. i have att u verse so i went into the cable menu to options. In the options tab i went down to system options then to aspect ratio. in this screen you get a few options like 4:3 standard definition and 1080i on high def screen. I chose 1080i high def and then played with the zoom function on my remote and the problem was solved. hope this helps
Posted on Aug 22, 2009
    Problem Solver:
  • 61 Answers
Does your format button not work or aspect or picture size it may also be in the menu some pictures yo can't change
Posted on Nov 19, 2008
Bad picture on Samsung HP-R5052 50 in. Plasma HDTV
Hi there!
I suggest changing the screen , it is getting worn out
peace.
May 18, 2017 | Samsung HP-R5052 50 in. Plasma HDTV
Satelite Dish
please tell the model number please.
reply.
Oct 29, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
The picture has gone on my Samsung 50 inch plasma tv. I have sound only. Don't know if it's worthwhile getting it fixed or if I should buy a new one. It's only three years old.
Plasma tvs are tricky for picture. They use two boards to burn the plamsa gas instead of one (LCD)...This almost doubles the price for any replacement boards, unless you know componenet level repair.
Overall, if you can find someone that will work cheap and knows what they are doing...then yes it isn't the most intence repair...but if NOT...then it's probalby too expensive to buy the replacement baords.
Thank you!~
Jun 16, 2011 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Picture went out on me its brand new tv voice is there what happend
if you see the volumn bar on the screen when you adjust the sound then the tv should be OK. So look for HDMI wire not inserted fully or what ever wire sends your info to the tv from your cable box, satelite box, or whatever. Or does anything show at all on the screen that you can see, like snow on antenna without a signal input. Maybe a real problem.
Nov 21, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
I have a Z50PX2D 50 in. HDTV Plasma Television I replaced the y,z susp boards and the 2 driver boards. I got a picture back but on most of the digital channels there is bad picture quality, still...
Hi and welcome to fixya.
To answer part of your question;
Whitout having the complete story on your tv and what prompted you to replace the Ymain and drivers along with the Zsustain.
I would suggest that you look on the back panel, you will see a sticker with voltages written on it.
For a 50" plasma set it should be somewhere around 195 to 205 volts for the VS voltage.
There is a control in the power supply circuit to adjust that voltage that usually can be measured on one of the fuse of the Ysus or Zsus.
You can also vary that control slowly while you look at the screen and you will see a difference(sparkles) in the picture.
It might just be what is missing now to repair your set.
Good luck and don`t forget; this is a freebie so you can either say thank you for the advice but no thank you or just thank you :)
Oct 21, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
Watching a football game picture is very unclear
The noise reduction option will cause a blur on fast movement. Also, you probably already know this, but a standard definition broadcast will look very blurry on an HD TV, so make sure the channel you're watching is actually an HD channel.
Oh, wow, I just noticed that this is from October. Oh well, maybe you're still having problems.
Oct 18, 2009 | LG 50PS60 50 in. Plasma HDTV
Top And Bottom Of Screen
If you are useing a cable box or satelight rec. Check the format that you have it adjusted to. If not adjuste the format of the tv. If that does not fix it, it will need to be adjusted by a tech.
Mar 21, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Fill the screen
Depending on what source you are using, this is possible. Most digital sources are set and cant be changed by the tv leaving black bars. Though video, svideo and component should allow multiple masking and cropping modes to strech the picture.
Nov 01, 2007 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Insignia LCDTV26 26 in. Television Logo
873 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
