Question about Advueu Technology ADV178T 17" Flat Panel LCD Monitor
One monitor clear the other not good fonts
One monitor is displaying very easy to read display while the other monitor is working fine but can't seem to get the font display to be as clear as the other monitor. One monitor is a Dell 17" flat screen (pretty basic monitor) the other monitor is an AMW 17" flat screen. THe AMW is about 3 years old the Dell is the same age. The Dell is clearer and easier to read than the AMW however the dual monitor setup is set with the same resolution (1280x768) on both units but the AMW is displaying a font that looks abit like the clear type is not selected but it is selected on both u nits. What can I do to make both monitors have similar displays (probably won't be exactly the same clerity but need them closer than I have been able to get adjusted to) Please help me with some ideas or something. THanks in advance Harley Brotherton
email is hbrotherton.aareg@gmail.com
I installed a better video card that supported dual monitors without splitting the signal.
Posted on Nov 26, 2008
I have a lg flat screen monitor, the words are blurred
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
Apr 02, 2012 | LG 22" FLATRON LCD Monitor
While working on my laptop it suddenly become blurry, the images are seems mirrored, the text become doubled and it hard to read. The graphics display was really blurry and even i open to safe mode still...
Look for a 9 pin or 15 pin plug on the side of your laptop. You can connect an external monitor to these type of jacks . If the display on the external monitor is clear then your laptop display panel is the culprit.
Jan 05, 2011 | Computers & Internet
Display is not clear in the monitor(colour is not orginal)
Right click empty space on desktop screen
see PROPERTIES in dialogue box ?
open SETTING TAB adjust fonts adjust setting for resolution also adjust choices in font shadow You can check box for clear edges of icons
Jun 11, 2010 | Intel Motherboard
Cant hardly read the screen the printing is so small and a little fuzzy
Change the display font size. In Win 7, right click on the desktop and choose Screen Resolution then choose make Text and other items larger or smaller. This brings up Windows Appearance and Personalization > Display (small, medium, large buttons). With Win7, you can also turn on Clear Type for LCD displays.
The earlier versions of Windows have the same display font option but it may be a subset of the Accessibility Control Panel. Macs probably have a similar control in the OS.
I hope this helps.
Apr 17, 2010 | Compaq Computers & Internet
I bought a dell monitor yesterday a 22" and the font seems so big how do i make it smaller
  1. make sure you have the resolution set to optimal 1680 x 1050 pixels.
  2. Set DPI to 96
  3. If font still to large, you can change the default font in display properties
Oct 16, 2009 | Dell Computers & Internet
Pc stops working/ganging after font size/pixel of
go to my copmuter--->right click--->properties.
Click on the HARDWARE tab ---> Device manager
click the (+) on display adapters and see the name of your video card.
Go online and download the relevant display update.
should solve the problem.
good luck.
Jul 11, 2009 | BenQ T900HDA Widescreen Monitor 18.5 inch...
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
.ct 2070 display not clear
Are all the fonts unclear?
Even when you open a document such as word and notepad?
If the answer is yes, it might be that you've got a problem with your windows setting. maybe you should try adjusting as follows:
>click on properties on your desktop
>click on the appearance tab
>click on effects button
>check the box "Use the following method to smooth edges of screen fonts"
>click on ClearType
Jan 13, 2008 | Microsoft VIEW ERA 19 V191HD LCD 500:1 .29...
Advueu Technology ADV178T 17" Flat Panel LCD Monitor Logo
154 people viewed this question
Top Advueu Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
