Question about Hoover U5432-900 WindTunnel Plus Bagged Upright Vacuum
Windtunnel strange smell
My vacuum started to smell hot, then the belt broke. The belt didn't even look worn out at all. It sort of looks like it got stuck and melted in one spot. My belt was a 38523-033, but I couldn't find that one. The store had Style 160 for Hoover Windtunnels, so I bought that one. It is a little bit shorter, but I was able to put it on. But, when I used the vacuum, it still smells hot. It is picking up fine. I didn't continue using it because I didn't want another belt to break. Do you know what may be causing this smell, like hot rubber?
    Top Expert:
  • Hoover Master
  • 52,082 Answers
What the belt drives is jammed
Posted on May 07, 2017
  • 126 Answers
SOURCE: Hoover Windtunnel not picking up as well
There is a height adjustment on these vacuums and they are set to adjust in the "handle up" position". It will appear that the adjustment is doing nothing when the handle is up, but the setting will take affect when the handle is lowered.
You can check the brush length with a pen or pencil. Turn the machine over so that the brush is visible and run the pen or pencil flat across the bottom plate. Any where the brush is extending outward, your pencil should contact the bristle. If not, then the agitator should be replaced.
Also, check to make sure that the agitator is rotating freely and that the filters and bag are allowing for adequate suction. The machine will only pick up if the air flow is sufficient.
Posted on Mar 23, 2008
  • 97 Answers
SOURCE: Hoover Windtunnel shuts off
Sounds like you have a clog, which is a fairly common problem with these.
Check the air inlet immediately aft of the brushroll for clogs, then make sure the main wand and hose are also clear. If you have the machine on, check at the end of the hose for suction. This is a fairly common problem for all uprights with tools on board. Their airflow is very low, so they tend to clog up easily and then overheat the motor.
-R
Posted on Oct 01, 2008
  • 389 Answers
SOURCE: Hoover windtunnel..runs fine for 5 minutes then stops?
OK - sounds like your machine has a blockage somewhere. Follow manufacturer's instructions for clearing blockages and all should be well. If you no longer have the manual, you can download it from the Hoover website.
Posted on Mar 08, 2009
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
  • 18 Answers
SOURCE: hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Posted on Oct 08, 2009
After a few minutes of using my vacume it starts to smell like burnt rubber. like the belt is burningthe only belt I can see looks fine and is turning the brush
but how tight is the belt and how easy is the brush to turn? if the belt is slopy it will slip on the motor drive spindle,,,and it will get very hot then,,, also if the brush head is tight that makes the belt slip too,
Aug 11, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Belt is hot to touch
If the belt is hot or you smell it burning then chances are it has stretched a little and is slipping on either the motor shaft or beater bar shaft. If you are sure the beater bar is not restricted from turning then I would just replace it. Try this.. With the power cord disconnected, open the vac head to gain access to the beater brush and belt.. then remove the belt.. place the beater bar back into its holder and see if it easily turns by hand.. if it is free to turn..then plug the vac in and turn it on for a few seconds.. you will see and hear the motor come on but you should NOT smell anything burning at that time. If you do.. you may have another issue with the motor or power cord or both.. if you don't smell anything burning, then disconnect the power and just replace the belt.... Good luck.
Sep 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush won't spin
Yes it could be the belt or the "Bearing Assembly". I had the same problem with a vacuum I got from a friend. 1st I replace the belt,but when I turned the vacuum on I could smell something burning and then the belt broke in half. I then realized the brush roller was stuck in place and would not turn even with force applied. I later found out that 1 of the 2 Bearing Assembly's was worn out,when a Bearing Assembly is worn out the brush roller can not spin. So now it looks like I need to buy a whole new brush roller,unless I can find a place that sells the Bearing Assembly for part number 61445-1,which is a roller brush for a GE Wal Mart vacuum.
Dec 08, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5432-900 WindTunnel Plus Bagged Upright Vacuum Logo
258 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
