Question about Arris Wireless G Broadband Router (wr850g)
No connection with router
I moved my computer and have connected everything back up as it was. I cannot only get an internet connection straight from modem to computer. When I go through the wireless router there is no connection. I have the set up CD and have gone through all the steps, but no luck. I don't understand because the wireless router has been working for years and eveything was fine. I did not disconnect anything just unplugged and slid the desk to another wall and plugged the power source back in but now this problem of no connection through the router.
  • 78 Answers
Power cycle the DSL/Cable Modem and wait until lights cycle.
Power cycle the router and wait until lights cycle.
Reboot your pc.
It should work now.
Posted on Nov 19, 2008
    Genius:
  • 1,124 Answers
Check all the cables and connections first. Recheck if you did a good connections
Check if the router is working properly.
Check if the router is on range
Reset the router
Have NetGear N300 wireless router (wnr 2000v2)fed by motorola surfboard modem. N300 Port 3 output feeds OOMA internet phone system, Port 4 output feeds HP Touchsmart desktop pc (windows 7). PC will not...
hi,
go straight from your motorola to each wired computer to see if its a wire.can you can login to the router through your wired computer(touchsmart) in the settings and see if all your wired devices are listed, look at the parental controls, reset the whole router to default if you can, if your DSL. try a different jack in the house, get everything off that line but the motorola. go straight from the service jack outside the house(in the grey box) if you have to
jm
Jul 04, 2017 | NetGear N300 Wireless Router
I have an Emachine t5226 and have several external drives, a modem (speedstream 5100), and a netgear router attached. I was moving the externals, modem and router to a different area. I shut down...
Hello, Unfortunately, ISP techs often try to put blame on their clients equipment as much as possible. If your computer is showing limited connectivity, then this means that it is able to successfully connect to your wireless router, meaning that its probably not your adapter. Limited connectivity usually is a sign that you cannot reach the internet. This could be caused by multiple issues. In order to isolate the problem, try connecting your computer directly into your modem using the cable from the wireless router. If you can connect to the internet, then it is a configuration problem with your router. If not, then it is something with your connection to your ISP, in which case you need to call your ISP back and explain that situation. If you do happen to connect to the internet, then please reply, and we can go from there.
Feb 17, 2011 | Computers & Internet
I plug my router into my modem and it just doesn't want to work with me. Everything was working fine, and then last night my connection gradually got worse until I lost the Internet. I plugged my computer...
There must be a small reset button on your router. Hold it down for 30 seconds. Release it. wait for one minute. Now unplug the power and plug it back in. Wait for 1 minute.
Once you reset the router, it will come back to factory default settings.
You will need to reconfigure the router form the start according to your Internet service provider.
Click here for step by step instructions
Sep 26, 2010 | Linksys Wireless-G WRT54G Router
Everything appears to be working, but not internet connection
Turn off the firewall in both the router and the modem. try again-- once it is working ...just turn one of them back on..
May 16, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
MY LINKSYS WRT54G WONT READ MY COMPUTERS INTERNET CONNECTION
Ok to start the yellow ethernet port should be connected straight to the Linksys router in the ethernet in port. Then you connect the cmputer to one of the other the 4 ports on the back of the wireless router. wala you shouldn't have any more trouble after that.
Dec 03, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Wireless connection
Make sure that your computer is getting a valid IP address from the router. If your wireless network is secured, you might as well consider checking the wireless settings.
Oct 06, 2008 | NetGear WGT624 Wireless Router
Connecting
i have the same problem i moved and hooked everything up and now i cant get my router up and running or at least not with the internet. when it plug straight up to the cable modem i get the internet but when i hook it up to the network it has limited or no connection and i have been working on this thing for about a week. i think it is something small that i am over looking or something. i have it from the wall to the cable modem,from the cable modem to the router and then from the router to the computer. the cables i am using all work because i tested them straight from the computer to the cable modem and they worked
if you could help i would be greatfull and if need more info just tell me and i will do my best
Jul 04, 2008 | NetGear WGR614 Wireless Router
Internet
Start from ground zero
1. Is everything Powered up?
2. Check you internet connection
a. Can you directly connect to the internet by connecting a computer to the device providing the internet?
If this is good, then do this for later. ( it may not be needed but is good to have)
go to 'Start' -> 'Run' ->CMD[Enter]
Now you have a DOS box.
here
type CD \[Enter]
type IPCONFIG /all > ipdata.txt[Enter]
exit[Enter]
This copies the working IP Config that may be needed later.
Now connect in this order Internet connection to WAN Connection of router
Then connect one of the the LAN Connections of the router to
the working computer.
Turn off everything for 15 min.
No I am not kidding. Technical reason: Clear the ARP Table back at the ISP.
Restart the router then the computer.
Still no internet?
More details will be needed.
Router Make and Model
Internet Connection Type
Computer Make, Model OS and Version.
Good Luck
Jan 02, 2008 | Zyxel Prestige 660H Router
Connection Issue ~ D-Link DI 514
Connect to your router, then on the computer click start/run, type CMD at the >, type ipconfig /release, then ipconfig /renew this will reset all ip address from your computer through your router to your modem. this should fix the problem. BPCS
Dec 30, 2007 | D-Link DI 514 Wireless Router (DI-514)
On and off line every 20 flashes.
Have you attempted to connect the internet after the router stops flashing? Do the lights start flashing again? If you do, then it would be considered normal.
If they don't and you do not have an internet connection, try the next step.
Next, plug your computer straight into the modem - Do you have an internet connection now? If you do, your router may require configuration.
Nov 10, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Arris Wireless G Broadband Router (wr850g) Logo
94 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
