Question about Gateway 507GR PC Desktop
USB devices not always working on Gateway 507GR
I have a printer , 2 usb disk drives , and a zip attached to USB slots on a Gateway 507GR . At first they worked just fine but now, they drop off and cannot be seen. If I unplug and replug they sometimes come back and sometimes they do not. I get messages like USB device not recogonized and can't write to drive. Can you help me with this problem? Thanking you in advance for your cooperation.
  • Anonymous Mar 12, 2014
    can i use linksys wireless usb adapter on the gateway 507gr
    Novelist:
  • 100 Answers
Truthfully, I've found this to be true about most USB ports -- when more than two devices are installed. I'm not sure there is a real fix for the issue. It's kinda like wifi. It works and it works good, BUT it's not 100% (all the time). It's just the nature of the technology.
Posted on Nov 19, 2008
Toshiba external hard drive not detected
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
Windows 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Some external storage devices work poorly or not at all when connected to a hub; try connecting the drive directly to a port on the computer.
Also check if it's detected in "Disk Management".
Here you can verify if the partition and format are correct for the Operating System.
Check the Drive's status in Device manager.
This will verify if the external drive has a drive letter designation.
Check Partition and Format.
Log in as Administrator account in windows or any other account with administrative privileges
Insert your removable disk into the USB port.
Click Start, right click on computer and select manage.
Now, click Disk Management.
Check whether drive letter for the device is present.
Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc).
If the device is detected with a drive letter, verify that no other device is using that drive letter.
If it is, change it to unused drive letter.
if you dont have a disk with the drivers
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
hope this helps
Sep 18, 2012 | Toshiba 10TB USB 30 Desktop External 1 TB...
Hard disk not detected sometimes
I can think of 3 possible causes to your problem:
1. Faulty cable - try replacing the cable by borrowing a working cable from a friend. If this solves the problem then you need to buy a new cable
2. Lack of power - some USB drives especially those for high capacity drives require extra power aside from that provided by USB. If you do not have a separate power leading to your drive, check if there is a separate power slot and run a cable from it to your outlet/USB slot. Just make sure that the voltage levels are correct.
3. USB Slot - some laptops' USB slots do not produce power enough to drive a hard disk. Other devices may work (e.g. keyboards, mouse) but not hard drives. Try to use another slot in your laptop. If this works, remember to use the same slot next time.
Hope this helps.
NOTE: Please rate our help to keep this free service online
Jan 08, 2010 | Western Digital External USB 2.0 80 GB...
Does the 507GR support Wireless internet?
It is possible if u buy yourself pci wireless card. and connect it do your computer the second possible way is usb wirless adapter.
If helped rate fixya
May 03, 2009 | Gateway 507GR PC Desktop
Samsung Pleomax SAM MD-205 driver?
It took me a lot of digging to try and find a driver download. You can try the UHD25-80GB driver (this is for Windows 98, but you can try to see if it fixes the problem): http://www.samsungpleomax.com/sup_03_01.asp?page=2&fcate=Driver+download&scate=Storage+Media&tcate=HDD&scateg=Storage%20Media&tcateg=HDD. Direct link to zip file: http://www.samsungpleomax.com/sup/cs/HDD-driver-2500-80GB%20DRIVER.zip
Also, specs indicate that you need USB 2.0 or 1.1. I had problems connecting via a 4-port hub (that was supposed to support USB 2.0) so ended up connecting directly via my computer USB ("Enhanced" = 2.0) slot, which seemed to work fine.
Apr 04, 2009 | Samsung Zirex Pleomax 80GB Portable Hard...
I had a computer with a slot for reading iomega ZIP 100 disc. My new computer does not have this. Is there a device to read my zip dizc and send the contents to a USB port?
IOMEGA make a USB ZIP drive that reads and writes 100 and 250 Mb disks. Don't know if this is available any more, you might be able to pick one up 2nd hand.
If you still have your old computer, try networking your old and new computer together so you can transfer data from the ZIP drive on your old computer to your new one.
Mar 21, 2009 | Iomega Zip 100MB (31714) External ZIP...
When i plug the my pan drive with USB then my computer display such type of massage "one of the USB attached to this computer has malfunctined , and window does not recognize it"
Try to attach that pen drive in another slot and if its work fine than always use that slot.
If its not working fine or showing that malfunctioned error than please update your USB driver of your machine.
Mar 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hi tried that... sound card is connected and vm-ware tools is also installed... its surely a problem with the windows 2003 server. because the error sound is played through the macbook speakers but not any...
see heres the thing when using VM-Ware, VM-Ware doesnt use drivers for your physical hardware, because it emulates the hardware that is seen in the hardware information of your system preferences.
So installing even drivers for the "emulated" hardware will not work, as VM-Ware uses its own drivers for the hardware, which are included with the VM-Ware Tools, if that doesnt seem to work, you may want to contact VM-Ware support, as they may have a better solutiuon.
Aug 29, 2008 | Intel Motherboard
HOW TO FORMAT A WRITE PROTECT USB DRIVE
repair_v2.9.1.1.zip
good program. kdt100-4gb now is ok
Apr 05, 2008 | Kingston Technologies 512MB DataTraveler I...
MY KINGSTON DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO HAVE A WRITE PROTECT DISK.
I had same problem. I fix it with suggestion of 1st guest. I download program from site http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip, and program formated USB and he work fine now. TY for advice.
Jan 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Gateway 507GR PC Desktop Logo
110 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
