Question about Quantum Fireball Plus AS (QMP30000AS-A) 30 GB Hard Drive
Primary Drive 0 is not found when I boot my computer
Summary: dell optiplex gx150 desktop series. Win 2000 Pro. Quantum Fireball Plus AS 10.2 GB hard drive. INSTALLED Trend Micro PC-Cillin 2007 Internet Security antivirus. Never worked again. Could be coincidence.
On start, screen says "Primary hard disk drive 0 not found." I enter bios and it says "Primary Drive 0" ... "Unknown Device". I enter Unknown Device area to set it and "Drive type" is set to "auto". I am not sure if I should "arrow" up or down to change this setting: I don't know what I would change it to.
Meanwhile, I researched restoring bios factory default and ran through the functions: F2 at Dell screen. All on for "Num Lock," "Scroll Lock," and "Cap Lock". Tried hitting Alt F then Alt P. Then tried Alt e and Alt F. Nothing changes. I've removed CMOS battery, unplugged and removed hard drive fully, unplugged machine all night, restarted machine next day and went through resetting bios again.
I've seen something about running some program, but I am not an expert, don't have the tools, and can't understand how the machine can run anything without the drive. Also, I am not original owner so don't have the initial Dell install CD.
Please don't tell me it sounds like the motherboard, if it does, should I scrap the entire machine? Doesn't sound salvagable if it is motherboard.
Thanks for any help.
  • 928 Answers
First things first use teh arrow keys for left and right to select auto for the primary drive. If when you reboot and the drive is not seen then double check if the hard drive is set to master you can see the jumper settings and how they should be set on the top of the drive itself. Then check the power if the drive feels like its vibrating then its ok. After that turn on the computer. If after that the drive is still not detected then you might have to consider that the drive is defective and i would suggest you try another drive and see if it is detected.
Kindly reply back for additional questions.
Posted on Nov 19, 2008
2 Suggested Answers
MalKontent68
  • 748 Answers
SOURCE: Different WIndows operating systems on two hard drives
1) Try if Cable Select will work for you, meaning that the existing HDD will be Master, and the Quantum will be Slave. If there are problems in identifying the drives by BIOS, manually set the existing one to Master, and the Quantum to Slave.
2) You don't have to install anything on the second drive. The operating system has to be installed on the primary drive, from which the system boots.
3) If the Quantum drive does not contain anything useful, it would be advisable to go to Management Tools, Disk Management and delete the partition from it, re-create it, and format as NTFS - under WinMe it was surely formatted as FAT32, which has a file size limit of 2GB and doesn't let you set any access permissions.
If you don't need NTFS, then at least re-formatting the drive would be advisable, as it's the simplest way to get a clean drive, without unwanted stuff (like WInMe, programs installed on it etc.) and no data fragmentation, that occurs with time and slows down the drive operation.
4) You might need to go to Disk Management anyway to assign a drive letter to your newly attached drive - most probably your existing drive is C, your CD/DVD is D, so you'll have to assign letter E to it, or better yet, some letter further in the alphabet, like Q for example - especially if you use external disk devices, like flash pendrives etc., which already were assigned the letter E when you used them.
5) With the harddrives so cheap nowadays, does it really make sense to use an old hdd? They have a finite life time, and the older the drive, the more chances are of it failing, and you losing your data. Maybe it would make more sense to buy a new ATA drive and use it instead?
Good luck, and don't forget to come back with a testimonial if helped :)
Posted on Dec 13, 2009
My optiplex gx150 is telling me that the primary hard disk drive 1 is not found what can I do
This message means that the BIOS is unable to find a drive with an Operating System to boot from.
Typically this means that the IDE cable that connects from the motherboard to the Hard Drive is not connected
It may also mean that there is no power cable plugged into the Hard Drive.
Check those first.
Apr 24, 2010 | Dell OptiPlex GX150 PC Desktop
Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Mar 09, 2010 | Dell Optiplex GX60 PC Desktop
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
Dec 13, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
I am looking for a Quantum Fireball 20.5 GB hard
The board alone is not available for sale. To recover the data you will need to buy a 20GB Fireball with same board and swap the control board.
You can buy a 20.GB Fireballl QMP20000AS-A from links below:
QUANTUM QMP20000AS-A - Buy Now at Cuetech, Inc.
QMP20000AS-A DELL 20GB 3.5" IDE 7.2K HARD DRIVE
Quantum QMP20000AS-A Fireball Plus 2 QUANTUM FIREBALL PLUS AS 20GB HARD DRIVE QMP20000AS-A -
Oct 22, 2009 | Quantum Fireball Plus AS (QMP20000AS-A)...
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Jumper go`s in what line.if power out let it on my right handside
moz-screenshot.jpgHere is a picture I found that shows the jumper settings for:
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
http://www.tacktech.com/images/articles/379/mxo_ata_jumpers_2.png
Apr 26, 2009 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Windows 2000 won't recognise my current HD driver
you cannot up grade from win 98 to win 2000
There is too big a gap in technology to allow it to happen
you have to remove the win 98 operating system and install the win 2000 operating system
That basically means re-formatting the hard drive so save all files and folders to an external storage facility
once you install win 2000 the driver will be installed automatically
Sep 12, 2017 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
Quantum Fireball Plus AS (QMP30000AS-A) 30 GB Hard Drive Logo
401 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
