Question about Datamax M-Class Thermal Printer
Can I use the print perferences to configure the datamax M Class that doesn't have a display window
  • 27 Answers
Yes, you can use the print preferences to configure the Mclass printer depending on the settings you want to make. You can change the print speed, heat, and even send commands to the printer if you wanted to. However, a much better solution to make changes in the printer to download the Datamax Printer Configuration utility from here: ftp://ftp.datamaxcorp.com/dmxConfig/Datamax%20Printer%20Configuration%20Utility.exe . This allows you to make changes in the printer without the need to use the buttons in the front panel. Hope this helps.
Posted on Dec 29, 2008
My Datamax H Class thermal printer is "stretching" the image from a Bartender file.
if you open the image and double click on the barcode you want to shrink you can move it around and make it smaller
Nov 10, 2017 | Datamax Office Equipment & Supplies
DATAMAX E-4203 ONLY PRINTING HALF OF THE BARCODE
I doubt the sensors would have anything to do with only printing half a label. I'm not familiar with the E-class series of printers, but the common causes of that problem that I've seen before with the larger M & I class printers can be:
1) A piece of label or ribbon is stuck on the printhead.
2) The printhead is not seating properly on one side, causing the printhead to be too far away from the label & platen roller to apply enough pressure in order to print.
3) A printhead cable is not seated fully somewhere and not supplying the signals properly to that half.
4) The main logic board is bad.
5) The printhead is bad.
6) There is a software problem or label configuration setting that needs to be corrected that controls the print width.
Feb 26, 2014 | Datamax DMX E4203 Printer
Dmx-4204 and zpl
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Jul 23, 2013 | Datamax E-CLASS DMX-E-4204 Label Printer
Do you have downloads for Datamax Drivers? Mainly, E-Class
Free Windows Printer Drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Jun 09, 2011 | Datamax M-Class Thermal Printer
We have just gone live on sage 1000 and are trying to print labels designed in sage paperless to send to our Datamax m-4206. Labels print but we cannot get the information to line up on the labels. Is...
This can be caused by either the software, or the printer's electronic or mechanical settings. Software will usually override the printer settings for print speed, temperature, label dimensions, etc. In order to fully diagnose, I would need to know if the print is too high, too low, too far left or right, or skipping a label, etc.
Nov 08, 2010 | Datamax M-Class M-4206 Thermal Label...
Datamax I-4208 Cutter Fault
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
Oct 02, 2008 | Datamax M-4208 Thermal Label Printer
Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Aug 25, 2008 | Datamax M-Class Thermal Printer
Datamax E class
Go to Control Panel > Pritners and Faxes. You should be able to see your printer there. You can check and ask it to print a test page.
Jun 05, 2007 | Datamax 1/PK EXTERNAL LAN INTERFACE METO...
Datamax M-Class Thermal Printer Logo
288 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
