Question about IBM NetVista PC Desktop
It takes @least 30 minutes to boot
My laptop internet has wireless connection thru my desktop
it takes turning the computer on and off for @ least 30 minutes, the message that comes up is "no operating system found". Once on it freezes a few times and I have to turn off and on, it comes right back up, after several freezes it stays on and runs well. Are all the updates necessary for the computer to run correctly, can't you download the when needed.
HP pavillionze4200. Do not have original cd rom. Windows XP.
Thank you all for your help.
Can you help me.
  • josephinemyr Nov 20, 2008
    it is a hp pavillion laptop,said it was laptop in the first sentence, and type at the end. windows xp, not vista
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    is this on the laptop or the desktop?
    Genius:
  • 1,124 Answers
It sounds like your computer is not recognising the hard drive. Go into the bios (keep pressing the delete key as your computer starts up ) and find 'hard drive auto select' and press enter to see if your computer can recognise the hard drive. Even if this works it sounds like your hard drive is on the way out.
1/ Make sure no floppy or CD in drives
2/ Check Hard Drive cable connections, both ends
3/ Go into BIOS and check drive is recognised in there
Posted on Nov 19, 2008
Need to connect reurbished dell GX520 to existing internet
first connect the "cat 5" cable to the dell's network card, the card has a square-ish hole with a little "cutout" in the top (for the cable's connector tab) the other end of the "cat 5" cable goes into the back of the router (you do have an existing router?) into one of the un-used square-ish holes (same cutout for the tab).
Then turn on the computer, see if the computer will "connect" to the router (that means it sees the router in computer-ish software).
IF that works then connect the router to the Modem (supplied by the "Internet Provider"... Then turn on the modem....
IF all goes well, your computer will now be able to connect to the existing internet.
Now for problems...
IF it seems to be connected correctly using the proper cat 5 cable, and it still will not work... turn off everything, start with the internet modem, then the router, then the computer... COUNT to 30 (1, 2, 3, 4... 29, 30) turn on the internet modem... count to 90 (1,2,3,4...90) turn on the router... count to 30 (1,2,3,4...30) turn on the computer... wait for it to fully boot, look down at the lower right of the screen and see if it can connect now.
IF it still doesn't connect, you may have to try another network card in the computer, or get a wireless USB "thingy" to connect to a wireless router...
Hope this helps...
May 21, 2014 | Dell OptiPlex GX260 PC Desktop
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
I do not know how to connect to internet thru wi-fi with my aspire 4738Z
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 21, 2011 | Acer Aspire 4730-4947 Notebook
Can't get the wireless to work from my wifes computer to my laptop. It eventually boots up so I can access my internet explorer but it takes 25-30 minutes. Dennis
The problem is not your router is your ISP or internet provider.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 18, 2010 | 2wire (1000-400108-001) Router
SETTING WIRELESS
1. Shut off the power to your cable or dsl modem for about 30 minutes.
2. Connect the ethernet cable from your modem to the Internet port on the router.
3. After 30 minute power on ONLY the modem NOT the router
4. Wait about 60 seconds and power on the router
Try it now.
Oct 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I have a same problem..
check the router interface and make sure that is the ip and subnet you have set for it 10.0.0.2 but you are right if the routers ip is set for 192.168.1.1 the laptop should be also 192.168.1.X
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 17, 2009 | Linksys WRH54G Wireless Router
Home network problem.
In order to resolve this concern just disable or configure your firewall and anti virus to allow the file sharing between those 2 computers and after that ping each computer if its replying but still cannot see the shared documents, do a power cycle turn off everything for 30 seconds and power them back after 30 seconds and that should make everything work....
Don't forget to rate the soluiton FIXYA thank you......
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
Got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
  1. power down ALL Computers and disconnect the desktop from the D-Link Switch.
  2. turn off all SLAVE AP's first.
  3. Turn off the Master AP and disconnect one end of the Ethernet.
  4. Turn off the D-Link Switch and disconnect one end of the Ethernet.
  5. Now, turn off your modem.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
  1. Turn on the modem. wait 2 minutes.
  2. Turn on the D-Link Switch and wait 1 minute. Then connect the Ethernet to the MODEM.
  3. Turn on the Master AP and wait 1 minute. Then connect the Ethernet to the D-Link Switch.
  4. Turn ONE of the Slave AP's. Turn on your Laptop. try to connect to the Internet. If successful, Disconnect from the network on the computer and proceed to turn on the rest of the Slave AP's, Laptops, and Desktop. If its NOT successful, power on the Desktop and try to connect to the internet.
  • If the desktop connects to the Internet, Check your D-Link's homepage "192.168.1.1" (default) for any wrong settings. If it does not connect, check your DSL Modem's settings.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
Aug 15, 2008 | D-Link AirPlus DI-524 Wireless Router
IBM NetVista PC Desktop Logo
313 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
