Question about LG 42LG50 42 in. LCD HDTV
LG 37'' LCD HD TV picture dsiplay includes 'ghosting'
I bought my LG 37" LCD HD TV about 6 months ago and noticed about 2 months in the picture started showing a 'ghosting' or outlining of images when there is a dark background and a light object in the foreground OR vice versa. Most noticable with the light object on dark background' I've tried everything in the set up menu but nothing seems to help. But it doesn't seem to be with every channel though so I'm not sure it is with the screen itself or with just certain channels. Any help would be greatly appreciated.
Seeing double :)
Shannen
Smooth_Gecko
  • 125 Answers
SOURCE: Connecting Rabbit Ears
If you are going through a VCR, make sure you have it in Port 1, or the primary connection. Sometimes they are sticking out the front and people use the alternate port at the back for tidyness, then it won't work.
Posted on Aug 03, 2007
  • 1030 Answers
SOURCE: Samsung hl-p6163w
ussally when u get coloerd outlined this idicates ether a convergence or a focuse problem.. the green convergence has become shifted. not lineing up with red and blue.. this also could indicate a green crt problem.. my advice is to get a tech to check it out.. it could be a simple adjustment or a whole new green crt
Posted on Dec 18, 2007
SOURCE: lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Posted on Mar 20, 2008
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
LaPavoniBoy
  • 36 Answers
SOURCE: spare parts for Vice Versa Coffee
Hi there, As far as i am aware all the vice versa places do not carry spares for the koala machines anymore. Im in scotland and tried, UK, Hong Kong, Italy, Spain and a couple of other with no luck whatsoever. I am a domestic coffee machine engineer and over the past few months have picked up some koala machines from here and there. If you contact David at coffeeservice@live.com and let me know what it is you are after, i can see if i have it and get it sent out to you at best prices and cheap postage. Don't worry i distribute worldwide and have had no problems so far. Let me know what you think.
All the best
David
The Domestic Coffee Service
Posted on Jul 08, 2009
Bought sony bravia 6 37" lcd hd tv 2 yrs ago +$1,500 when picture went dark, then out; srvc repair diagntc $75+tx. Now, we hv audio but only one channel wh cannot be seen & remot doesn't work. Were...
1,If you still have the old tv, reconnect.
2 turn on power after connecting cables making sure audio goes into ado and video into video.- very important.
3. do you get the pic, and sound?
4 if you do, do the settings to your choice.
will talk about new if the old does not work, good luck lindamilo.
Dec 25, 2013 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
37"RCA Lcd TV quit working
no parts available google model for part # for main pcb
Jun 08, 2009 | RCA L37WD12 37 in. LCD HDTV
No picture or response - LG LCD TV
Hi, I have the exact same problem. I was wondering if you could tell me how you fixed it? Mine is only 2 hours old from the box
Jun 03, 2009 | LG 42LG30 42 in. LCD HDTV
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
Lg 37 inch lcd tv model 37lg3000
You may have got a bad unit but more likly it's your cable you are using I have found with the newer HD units the siganal has to be real clean coming in or you do get a distorted picture. Try changing out you cable lead for a good quality cable,
Nov 16, 2008 | LG 37LC7D 37 in. LCD HDTV
Broken screen on a 37 inch hd lcd
That may have been an expensive tantrum - I doubt if it will be repaired as a warranty item and the typical cost of replacement makes it a costly lesson.
I doubt if the LCD panel is priced under $6-700.
Jul 01, 2008 | Olevia LT32HVM 32 in. LCD Television
I have no color on my 37 aquos sharp lcd
Give more info. In tuner mode, in component,rca or s-video input?
Dec 07, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
LG 42LG50 42 in. LCD HDTV Logo
81 people viewed this question
