Question about Cartier Roadster W62016V3 Wrist Watch
Armitron Driving me Nuts
I've been trying to remove the casing on Armitron and can't seem to do it. The casing has no grooves what so ever. I have the tool to remove the twist up casings but there are no groves. Also there is no edge to the cover to try to pry it open. I've lost countless hours and have even asked around. I could bring it walmart or a local jewler but I have three watches that are the same and I can't change there battery on any of them. Armitron Quartz Base metal Bezel 20/1381
6p05
I really need the instructions of an Armitron watch, not the model, but it is golden color, numbers and says pro sports.
You can find Armitron Watch Instructions at the Armitron website. I've included a link below for your convenience.
http://www.armitron.com/watch_instructions.asp
I hope this helps. Please let me know if I can be of further assistance to you.
--Sandy
Please be sure to Rate this message! Thanks!
Jun 07, 2011 | Watches
Cant set time
Hello, Ilbrownkid,
--Sandy
May 10, 2011 | Armitron Round Digital Sport 408089 Watch
I need to set the time in my Armitron 40/8105gry. I lost the manual and have no idea how to set time. It is to confusing so please send me a description of how to set the time.
--Sandy
Apr 30, 2011 | Armitron Digital Sport #40/8105GRY Watch...
I cant set my daughters Armitron Women's 456967PNK
Hello jchristen400,
You can find Armitron Manuals and Instructions at the Armitron website. I've included a link below for your convenience.
--Sandy
Apr 26, 2011 | Watches
Armitron Men's 204379BKSV Silver-Tone Stainless-Steel Bracelet and Black Dial Dress Watch, we replaced the battery and can't get the back on the watch.
Usually you would need a watchmakers press for closing the watch back. Without proper tools it is quite difficult, but you can try the following. Take a leather belt and lay it flush on an even, solid surface (stable table will do). Undo the strap (both ends) from watch case by pushing spring bars inwards with pen knife. Lay the watch crystal face down on the leather belt. Belt must be wider than watch itself and the leather must be quite hard and even, not soft. Find the small groove on watch case back and align it very carefully to the watch's winding stem, so, the stem goes directly in the middle in protrusion. Slightly push the case back into the watch case at that groove point and gradually apply pressure with fingers going all way around the case back. Use your body weight if needed. You should hear "click" sound when the case back jumps in to place. If this does not work, there is no other way, but to go and see watchmaker. Hope it will work for you.
Feb 27, 2011 | Watches
We can't get the back on after replacing the battery
Feb 27, 2011 | Armitron Chronograph Dress #204224BKSV...
Purchased armitron all sport 40/8083 watch---no instruction manual---where can we get manual to learn how to operate ie change time, date etc.
Hello Joanne,
--Sandy
Nov 18, 2010 | Armitron 165 watch
My lady's Armitron watch works perfectly. However the watch band which permanently adheres to the watch case has caused my wrist to break out where the clasp closes. this irritation has caused severe...
I suggest you try a self adhesive plastic or baise material. Clean the back with surgical spirit or methylated spirits before attaching the material.
Aug 07, 2010 | Armitron Watches
I need an extra link for my armitron watch band..do you know where i can buy one?
I REFUSE to pay for information about a simple little link for a watch. You people are nuts to ask for money
Nov 01, 2009 | Armitron Now Collection Butterfly...
Armitron y121e watch
If your Armitron has a set of 6 inset notches around the back, as does my Y121E 20/1791F Armitron Diamond, that's a screw-back case that does _not_ pop off or pry off. You'll need a case opener tool, which is basically a small tool with adjustable-gap jaws that fit into two notches on opposite sides of the case and let you unscrew it. Wal-Mart sells this tool for about five bucks, and it'll pay for itself soon enough, as many watches have screw backs, and this will fit most anything you find. Head for their jewelry department and you should find the tool hanging up with the replacement watchbands and batteries.
The case is probably screwed down fairly tight against its O-ring seal, so make sure the tool is seated properly in the case notches, and turn it slowly and firmly counterclockwise to work it loose.
If your watch is like mine, it'll take a #377 cell, but wait until you've opened yours up to be sure.
Sep 03, 2008 | JCPenney Armitron Sport Link Bracelet...
Cartier Roadster W62016V3 Wrist Watch Logo
262 people viewed this question
Top Cartier Watches Experts
k24674
john h
Are you a Cartier Watch Expert? Answer questions, earn points and help others
