Question about GoVideo DV1140 DVD Player / VCR Combo
GoVideo DV1140 combo DVD works fine, but VHS has LOTS of problems
I've no complaints about the DVD but whenever I tried to view a VHS tape (movie purchase/rental or just a show I taped) the tape starts fine, then sound is replaced by buzzing followed by TOTAL loss of sound and LOTS of static - then the tape comes back for about 15 seconds and sound is lost again, etc etc. This goes on sometimes for the DURATION of the tape and occurs even with brand new blank tapes that I've used to tape TV shows for later viewing. What's going on, and how can I fix this? I've even tried cleaning/demagnetizing the play heads with a tape cleaner I've had for awhile but nothing seemed to work.
  • dan_zig31 Nov 21, 2007
    Mine has a verry similar problem. My dvd player works just fine. But I've never gotten the vhs to work at all sence I've had this unit. Mine won't play anything, sound nor video when inserting a vhs tape. I've also lost the remote controle to it and none of the universal remotes I've tried had any luck operateing any of the menu functions other then channel and normal play operation.
SOURCE:
SOURCE: GoVideo DV1140 Unlock
You must push and hold power and dvd eject at the same time.
Posted on Oct 23, 2007
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
scramblepad
  • 66 Answers
SOURCE: region change to multi on govideo #DV1140
This might help some...no gurantees...... take care...
Kevin
GoVideo D2730
  1. Power up
  2. Wait for "No Disc" to bei displayed
  3. Immediately enter 7, 3, 8, 7, 9 (the last figure is for the region, 9 = multi-region)
GoVideo DV2150
  1. Open the disc tray
  2. Press 0, 5, 2, 0
  3. Press UP, DOWN, LEFT, RIGHT
  4. Press the button for the desired RC (0 = codefree)
  5. Close the disc tray
GoVideo DVP750 / DVP950
  2. Press 0, 1, 0, 6, 0
  3. Press the button for the desired RC (0 = codefree)
  4. Close the disc tray
GoVideo DVP850 / DVP853 / DVP855 / DVP860 / DVP865
  2. Press SETUP
  3. Highlight "Custom"
  4. Press 3, 3, 3, 3
  5. A menu should pop up (Secret)
  6. Select region (0 = region-free)
  7. Press ENTER
  8. Press SETUP
  9. Close the disc tray
GoVideo DVP1100 / DVP1165
  1. Turn on the player (without a disc inserted)
  2. Press PLAY 8x
  3. Press 0, 1, 0, 6, 0
  4. 9 should be displayed
  5. Press 9
GoVideo DVR4200 / DVR4250
  1. Change to dvd mode
  2. Insert a DVD and play it
  3. Press STOP
  4. Press PAUSE
  5. Press 3, 1, 4, 1, 5, 9
  6. Enter the region you want (0 = codefree)
  7. Press PAUSE
GoVideo R6640 / R6750
  1. region-free out of the box
GoVideo R6740
  1. Press SETUP
  2. Highlight "Exit"
  3. Enter 2, 9, 6, 0
  4. Press SETUP
GoVideo VR2945
  1. The disc tray has to be empty
  2. Press SETUP
  3. Go to the "System Info Screen"
  4. Enter 1, 1, 0, 1
  5. Enter the region (0 = multi-region)
  6. Press SETUP
GoVideo VR3840 / VR3845 / VR3930 / VR4940
  1. Press SETUP
  2. Scroll down to the lock symbol
  3. Keep Pressing 0 until it says "Congratulations region free!"
  4. Press RETURN
GoVideo D640, D645, DTH7000, DJ350, DP7240, DP8240, DP8440, DV1030, DV1130, DV1140, DV2130, DV3130, DV3140, DVR4000, DVR4100, DVR4175, DVR4300, DVR4400, DVR4550, DVR5000, DVR5100, GVP5850, GVP7811, R6530, R6540, VR1940, VR2940, VR5940
Posted on Aug 01, 2008
SOURCE: GoVideo Go Video VR3840 DVD Recorder+VCR rejects VHS C adaptor
tape ejects all the time when inserted
Posted on Jan 19, 2009
sodeep
  • 3267 Answers
SOURCE: DVD won't play
When this model was released, sheer versatile and packed with accessories and many bought because of accessories in the cabin, but the only catch was blue ray DVDwich were in HD format for improving the image quality. But the down side is as with previous optical disc formats, HD DVD supports several file systems, such as ISO 9660 and Universal Disk Format (UDF). All HD DVD titles use UDF version 2.5 as the file system. In the file system, a multiplexed audio and video streams are stored in EVO container format.
Plus all HD DVD players are required to decode linear (uncompressed) PCM, Dolby Digital AC-3, Dolby Digital EX, DTS, Dolby Digital Plus and Dolby TrueHD.A secondary soundtrack, if present, can be stored in any of theaforementioned formats, or in one of the HD DVD optional codecs: DTS-HD High Resolution Audio and DTS-HD Master Audio.For the highest-fidelity audio experience, HD DVD offerscontent-producers the choice of LPCM, Dolby TrueHD and DTS-HD MasterAudio.
Wheras HD DVD video can be encoded using VC-1, AVC, or MPEG-2. A wide variety of resolutions are supported, from low-resolution CIF, all SDTV resolutions supported by DVD-Video, and of course the HDTV formats: 720p, 1080i, and 1080p. All studio-released movie titles have featured video in a 1080-line format, with companion supplements in 480i or 480p. The vast majority of releases were encoded with VC-1, and most of the remaining titles encoded with AVC.
Now all such formats can be read/interpreted by using various media player whjich were capable of decoding whichever media player that player suited best. The way u can use/listen or see netfix DVD'd is to use a audio cm video covertyer to convert the entire DVD to a format compatible with your player, on to a pen drive or any such compatible device recognized by the nlue ray DVD player.
I do hope sincerely that you could the above abbreviations used in trying to explain WHY.......................................sodeep
Posted on Oct 28, 2009
GoVideo DV2140 DVD/VCR Combo Player/Recorder can i copy vhs to dvd on this product
The GoVideo DV2140 does not contain a DVD writer. It can only play DVDs and copy them to VHS tape.
I wish that I had better news for you. The manual is available at ManualsLib here: https://www.manualslib.com/manual/61649/Govideo-Dv2140.html .
Dec 21, 2016 | GoVideo DV2140 DVD Player/VCR
Dv1140-vhs has lots of static on screen and lots of buzzing from audio.
Hi, I suggest, manual cleaning with a swab, you will need to take off cover, inside is three heads, probably has dust, swab off with alcohol spirits
Jan 05, 2015 | GoVideo DV1140 DVD Player / VCR Combo
MY CHILD OF 3 YRS OLD ACCIDENTALLY PUT PARENTAL CONTROL ON MY DVD/VHS COMBO IS THERE ANY WAY TO UNLOCK IT
By parental control I don't know if you mean child lock. If that's the case you should be able to turn it off by pressing child lock on the remote control until off shows in the display window.
Aug 07, 2010 | GoVideo DV1140 DVD Player / VCR Combo
I have Directvhd and a Govideo 1140 combo. When I tried to play a dvd on input 1 get the movie with no sound, if I go to input2 I get the sound no movie it says progressive scan.
make sure the audio (red, White) is connected to input 1 and the video (yellow) is also connected to input 1. It should be labeled for indentification. Your video is on input 1 but your audio is on input 2 and vice versa. Check your connections again. Make sure your using the red white connections on input 1 for your audio and the yellow for the video on input 1. The above also applies to input 2.
Apr 23, 2009 | GoVideo DV1140 DVD Player / VCR Combo
No power to DVD combo player. VCR OK.
The power circuit for the DVD and the vcr are separate look for a open diode and transistor in the circuit that supply the DVD.GOOD LUCK.
Apr 26, 2007 | GoVideo Go Video DVD/VCR Combo
GoVideo DV1140 DVD Player / VCR Combo Logo
97 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
