Question about Kenmore 24 in. 16302 Built-in Dishwasher
Dishwasher Constantly runs, will not cycle off
I have a frigidaire rotary dial dishwasher. Model #FDB510LCS0. It will not turn off. When I left home this morning, i turned it on. 4 hours later, when I returned, it was STILL running. The dishes were clean, but it was still running. HELP please. Thank you.
Do use when not home it will catch fire!!!!
Posted on Jan 20, 2010
Turn on dishwasher you can hear it fill then it turns off
Some dishwashers have a delay start, (frigidaire has this). check the dial settings to
see if your unit has to have the dial rotated past the "delay start hours" setting. Hope this helps.
May 27, 2011 | Dishwashers
We have the Noma Exterior Mechanical No instructions. Shows on and off/dusk and then the hours. Do you turn to dusk and then the hours how do you set it to come at dusk then turn off 6 hours later?
Identify timer on following page:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Page shows instructions and troubleshooting.
That being said, if your timer has a dial with 2 4 6 8, then following instructions probably apply:
Timer turns on automatically at dusk,
Rotate dial to select when timer will turn off.
In your case, rotate dial to 6, and then timer will turn off 6 hours later.
Make sure to keep timer turned away from lights, or where car lights might reach photo-eye located on front of timer.
If timer is exposed to light, it will turn OFF, and then blink back ON few minutes later.
When timer turns ON again, the 6 hour countdown starts over.
Dec 22, 2010 | Garden
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
Dishwasher gets stuck on heating delay for hours
i have the exact same model with the same problem, i am hoping someone give us a solution.
Jan 21, 2010 | Frigidaire Dishwashers
Frigidaire fdb510lcs0 soap dispenser not opening
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once poweris applied to it. The BI-metal strip bends and allows the soap door spring toopen up the dispenser. This bi-metal strip is not given full 120 volts power,the timer "shunts" the power through either the heating element (most common ) or the motor and this gives the bi-metal strip lower than fullpower to work and open. Most often the bi-metal strip has lost its ability tobend properly and needs to be replaced. Older GE dishwashers used a mechanicalarm driven by the timer to open the dispenser = no electrical bi-metals.
Newer Frigidaire dishwashers and many newer Whirlpool dishwashers use a wax motor to open the soap dispenser. The plunger insidethe wax motor slowly moves and pushes the plunger and door open. And, if thiswax motor doesn’t receive 120 volts, then it’ll not work.
This will help you --
Please do rate this solution and revert for furtherassistance.
Thanks
Rylee
Sep 20, 2009 | Frigidaire Dishwashers
Dishwasher runs several hours
OK, that several hour wash cycle seems to be very abnormal and, the only way this can happen is if the timer control mechanism is damaged. this is referred to as a Overrun error. simply replacing the timer will fix this issue.
Jun 03, 2009 | Frigidaire Dishwashers
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Turns itself on
if it does this again then you will need to replace the cpu unit or main control board
Apr 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 24 in. 16302 Built-in Dishwasher Logo
228 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
