Question about Bose Lifestyle 28 System
Lifestyle 28 remote issues
Someone touched the codes under the remote cover and now my remote doesn't work is there anything i can do to fix this issue
snakehead
  • 1074 Answers
SOURCE: Bose Lifestyle 28 not playing DVD
my brother i am not familiar with that model but due to my electroincs experience all dvd players are make up of the the same principle.there is a flat strip that leads from the lens of your dvd player kindly remove it and replace it this strip is probably broken after doing this get a dvd lens cleaner and clean your dvd lens and your on if you cannot do it your self take it to a tech os that they can handle it.this job should cost about $75.00 US. enjoy Henry Thomas from Belize
Posted on Mar 14, 2007
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
  • 8 Answers
SOURCE: how do i get my Bose Lifestyle remote to control
call bose tech support and register your lifestyle system with them, they in turn will start sending you update CD's those CD's may include the new IR databases that would help you find the right code. the other alternative is to call VIaSat and find out what brand's IR codes they are using( and in the IR menu on the bose try that brand's codes) A lot of manufacturers will use the codes from Motorola(worth a shot) the alternative option is to program a universal remote to control your bose, and all your equipment (if your equipment is hidden in a closet, get an RF remote, I program these for my clients all the time (for their bose systems))
Posted on Sep 12, 2009
Ojelola
  • 22 Answers
SOURCE: can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Posted on Jan 26, 2010
SuperTech-11
  • 1591 Answers
SOURCE: I have a bose lifestyle 28 system purchased back
Exactly how "broke" is the remote? (pictures help here, but if you don't know how to post one, or how to keep it under 150KB in size, then be as descriptive as possible in a REPLY to this post.
Posted on Feb 27, 2011
I have a Bose Lifestyle 28/35 DVD system, and I haven't been able to find a code that works.
028,017,033,018,047 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 16, 2013 | Universal Remote Control RF20 LCD Remote...
I have a bose lifestyle 28 system purchased back in 2003. The remote broke when it was dropped on the floor (no longer functions). Is it possible to repair the remote or buy a replacement for this older...
Feb 27, 2011 | Bose Lifestyle 28 System
I own Bose system Lifestyle 28. my remote control does not work at a distance. if go 4 to 6 inches from the system it takes the command. what is wrong with my system/control system? My remote control...
The problem is that the broadcasting antenna at the top of the remote is very a very thin wire wrapped around a heavy cylindrical magnet and its solder points are extremely weak. You most likely dropped it and it came loose. I re-soldered mine and it worked perfectly.... until it broke again. The leads are very small and hard to fix.
Chalk it up to poor design.
It is hard to take apart... I got mine apart by wedging a screwdriver in and twisting until it popped apart. (nothing broke) I started at a bottom corner and worked my way up the side until it came loose. It is an easy fix if you know how to solder.
Sep 26, 2010 | Bose Lifestyle 28 System
My Bose Lifestyle 28 III system is about 2 1/2 years old. The remote has just stopped working---nothing at all. I have tried 4 sets of new batteries and still no luck. Any suggestions besides purchasing a...
A new remote is the simplest and best bet. I know of no way to repair a remote without making it irreparable. Though you might check the infrared LED i the front. Does the light on the remote illuminate when you press a button?(assuming it has that.)
Jun 22, 2010 | Bose Lifestyle 28 System
Can't hook up my bose system to my logitech harmony remote
From what I found on Giigle searches, it appears you need to buy a converter. Here is one of the links I found where someone gave a review on the remote and is in the same boat as you. But then I found this on Youtube that might help you. This link shows how to set up Logitech Harmony One with Bose Lifestyle 28. I don't know if this is the remote you have but maybe if you follow the steps, it might work.
http://www.youtube.com/watch?v=3nIbJPMGXv0&feature=youtube_gdata
This next link is the review, see the 2nd review where they talk about needing a converter.
http://reviews.pricegrabber.com/remote-controls/m/15474792/
Apr 03, 2010 | Bose Lifestyle 28 System
Bose dvd player powering on automatic
If you are referring to the Lifestyle system powering on, when you press the CD/DVD button on the remote control, that is the way the system is supposed to work. If this is not what you are referring to, please provide clear details on your issue. Thanks.
Dec 19, 2009 | Bose Lifestyle 28 System
Bose lifestyle 28 no power
There's no easy way to put this. This media center will need a repair. If you know the outlet works, and the power supply works. It couldn't be anything that's easily fixable. Make sure you don't have a dual-voltage power supply (red switch for 120v/230-240v). If so, change to 120v for us power. Otherwise this is pretty straight forward. You can call bose for a repair- 800-367-4008. $165 + tax flat rate. New 1 year warranty.
Jun 20, 2009 | Bose Lifestyle 28 System
(Bose lifestyle 28) DVD picture is distorted, shadowy and difficult to discern
Try the settings setup and adjust the brightness, video format, or video black level. If you're using component connections then adjust the video output. You can scroll system setup through the remote control settings button.
Nov 10, 2008 | Bose Lifestyle 28 System
Reomte code
gital lifestyles tv will work with LG codes 11423 for Direct Tv with this you can control volume, to control power put remote in tv mode
Dec 23, 2007 | Digital Lifestyle FA1B32Z 32 in. LCD...
call tech support to see if they can help, they might set up a repair for you
Nov 19, 2006 | Bose Lifestyle 28 II System
Bose Lifestyle 28 System Logo
49 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
