Question about Yamaha DV-S5450 DVD Player
We have a yamaha dvd player, model number dv-s5450 and it won't play our dvds. Sometimes it works but sometimes it won't even read them, tried cleaning lasers with laser cleaner and that didn't work any suggestions?
I had a similar problem...the machine, which had been great up until then, started to be very fussy when loading a disc; using a lens cleaner did not help at all.
I opened the disc tray and used a can of "air duster" with the straw attachment blowing in lots of air into every little nook and cranny that I could reach, especially in and around the actual lens area. The liquified gas under pressure must have been too cold as, at first, there was no improvement whatsoever when I tried playing a disc. However, the next day the player was working perfectly again.
It is worth a try.
Posted on Dec 08, 2008
Samsung htz310 reads NO DISC
probebly a bad laser. sometimes they will play music but not dvds or even the other way around. from what iv read this is happening to people in just a few weeks.
Nov 19, 2011 | Televison & Video
I had the dvd player/radio /cd player replaced in my 2007 Yukon, the cd player would not read discs, the dealership ordered a new radio & now the dvd player reads disc region error & will not play...
If your using copies then some dvds wont read them even if the old one did, sometimes its a gamble if it reads or not, if your using a master then i would have them check it out, it may be bad or need programing, it funny because sometimes it will play a copy and sometimes not, thats what i've run into. hope this helps.
Aug 31, 2010 | GMC Yukon Cars & Trucks
My dv s5770 (yamaha)takes a long time to read the disc, if it does at all. sometimes it plays, other times it stops and skips to the next track/chapter. It goes from reading to dvd to info on the display...
The lenses of your dvd has a dust on it. You need to buy a cd cleaner , or you have to open the dvd and locate the lenses. Clean the lenses using cotton buds with alcohol.
Jul 23, 2009 | Yamaha DV-S5770 DVD Player
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Unlock sony DVP-FX720
The problem may be you are trying to play DVDs from a specific region (Europe) and the player is set for another region. Region code errors will show up as "no Play" or 'region" Check the manual to see how to set the player to Region 0. A region machine will play any DVD. Sometimes the setting is on the menu - usually in the set-up screen under "region." I have re-set all my Phillips players to become Region Free through the menu.
Aug 22, 2008 | Yamaha DV-S5450 DVD Player
Region code locked
my v.zon plays but cannot see picture clear it is a portable dvd player.
Apr 19, 2008 | Yamaha DV-C6660 Multi-disc DVD Player
Daewoo DV-6T955B DVD Player Problem
If your DVD is less than a year old, still under manufacturers warranty.
The problem you have "no Disk" is because the laser is not reading the DVDs.
Call the Main support number at 800-323-9668
Support FAX 973-384-9250
Email support service@e-daewoo.com
Mar 06, 2008 | Daewoo DV-6T955B DVD Player/VCR
Reading Reading...
What kind of disc are you attempting to play? If you are trying to play a home-recorded disc, the disc may not have been finalized for compatibility with other players. Try a commercial disc and see if you get the same message.
Jan 18, 2008 | Yamaha DV-S5450 DVD Player
BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Blocked error message
I would imagine it's eitehr a Region problem or a parental level problem. Ensure the region DVD matches the Region of your DVD player. Also check the parental rating level within the DVD player is not active or set to 18.
Jan 26, 2006 | Yamaha DV-S5450 DVD Player
Yamaha DV-S5450 DVD Player Logo
176 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
