Question about Dryers
Dryer doesn't heat and runs constantly
The dryer runs and the timer goes to a certain spot then stops and runs constantly but there is no heat at all
    Problem Solver:
  • 7 Answers
Depending on the model; if the timer is in the automatic cycle it will not advance if there is no heat, it must heat in order to satisfy a thermostat to tell the timer to advance this is what makes it automatic. If the timer gets to the end of the timed cycle and will not advance to off, sounds like a bad resistor connected to the timer, I would first check the heat circuit to find out why its not heating. Dont mean to complicate, but everything in the dryer has something to do with heating, element,thermostats, temp switch, timer and even the motor. Check for burnt wires at the terminal block for the cord. hope this helps.....
Posted on Nov 19, 2008
My dryer heats but doesnt stop wben timer is set
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Sep 11, 2014 | Dryers
Dryer no longer heats up
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Jan 18, 2010 | Whirlpool LER5636P Electric Dryer
Dryer is not heating. the dryer timer goes all
HI, The timer control module is the culprit. This device controls the heating functions of your unit. You have indicated that the timer will not stop the unit, and it continues to run after the cycles intended stopping point. This will confirm that the timer is damaged, and it should be replaced asap, if possible.
NOTE:-( Just to be safe, check the thermal fuse as well. This is a emergency cut-off fuse that will blow if the element overheats your unit. it is located on the blower housing, or vent duct inside the unit. Test the fuse for continuity. If it is ok, replace the timer).
Oct 16, 2009 | Dryers
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Whirlpool electric dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Timer does not advance, dryer keeps running.
in auto dry the timer motor receives voltage to advance by way of the cycling thermostat.[each time the thermostat opens to stop the heat the switch in the thermo then changes that voltage up to the timer and it will advance timer motor until it closes again for heat and this continues till clothes are dry]so as long as timer is receiving that voltage and not advancing then i agree its the timer.other wise it could be a failing/intermident cycling thermostat.a timed dry the timer motor receives constant if never stalls in timed dry it may be a clue that the timer is ok. i hope this helps you understand whats going on. God bless ,tom
Jan 23, 2009 | Dryers
Dryers Logo
279 people viewed this question
Top Dryers Experts
