Windows7 intel pentium processor
Jeremy,
1) Photos:
Right-click on the photo.
In the list click on - Save Image As
In the window that comes up, look to see where the photo/s will go.
If this isn't where you want the photo/s to go, change to a sub- folder.
Example;
http://en.wikipedia.org/wiki/VGA_connector
I'm going to save the photo of the Video Cable on the top left.
I right-click on it, then click on - Save Image As - in the list.
I have it set up to download to a sub-folder, in my My Pictures folder.
(Windows XP)
2) Stories:
For this I use OpenOffice, and Writer.
In Microsoft Office you would use Word. Open - Word, have a blank page ready. (Blank document)
Go to the page you wish to copy, and copy, and paste the words.
Don't forget to give the file a name, and a name you will remember.
Copy and Paste;
For the above you start at the first letter of the first word.
Example; Start.
Put your mouse cursor on the S. Left-click, hold the left mouse button down.
Move the cursor across the sentence, and then down the paragraph, or paragraphs.
This highlights the words in Blue.
Now hold the CTRL key down, and at the same time tap the C key.
(On a lot of Keyboards the C key also has Copy on the side )
Go to the Word document you have created, and left-click at the top left corner.
Now hold the CTRL key down, and at the same time tap once on the V key.
(On a lot of Keyboards the V key also has Paste on the side )
Takes a little practice to copy the article. (Story)
3) Web pages:
Same as above with Stories. Only problem is the web page is set up in a different format, than Microsoft Word.
You can't copy the entire web page, and have it come out in Microsoft Word, as it was on the web page.
You can copy certain things off of the web page, however.
Remember, you cannot use someone else's web page on your own.
That is Plagiarism.
Coping documents, (Stories, bits of web pages), is difficult to explain with the typed word. Would be easy to show you.
Hmmmm,
http://www.youtube.com/watch?v=c66pvfilotA&feature=related
Regards,
joecoolvette
Download what?
SOURCE: monitor stays black
try to clean your memory using pen or pencil eraser..
and if the problem stay the same, try to use another monitor.
SOURCE: cpu upgrade , please help
tech-gu818,
When looking to see what processors a computer will support, try to find out what motherboard chipset is on the motherboard, and the processor socket.
The motherboard chipset is the;
1) Northbridge chip
2) Southbridge chip
[Chip and Chipset are slang terms for Integrated Circuit, or IC.
A Processor is one type of Integrated Circuit]
The Northbridge chip is responsible for handling the Processor, Ram Memory, and high-speed graphics, such as AGP, or PCI-Express.
Integrated graphics, or a graphics card installed in a PCI slot, is handled by the Southbridge chip. The slower capabilities of a computer are handled by the Southbridge chip.
This motherboard diagram may help further illustrate the above statements,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(You can also type,
1) Northbridge (computing)
2) Southbridge (computing)
in Wikipedia's search box to obtain more info )
How to find out what motherboard chipset the eMachines W3502 uses?
Three ways:
1) Go to the computer manufacturer's support website, and look under Specifications.
2) Download the free, tiny, program CPU-Z from CPUID.com
3) Download the free, tiny, program Belarc Advisor
Fortunately eMachines Support lists what the W3502 motherboard chipset is,
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3502
Chipset: ATI Radeon XPress 200
Now look for information on ATI's Radeon XPress 200 chipset.
For this we can go back to Wikipedia once more,
http://en.wikipedia.org/wiki/Ati_radeon_xpress_200
Reading the top sentence in the first paragraph you will note,
".......Pentium 4, Pentium D, and Celeron processors, ......using either a Socket 478 processor socket, or an LGA 775 processor socket."
What isn't stated in the first sentence is that it will also support Intel Core2 processors. That is stated on the right side of the page, in the information box under the subheading - CPU Supported
I wouldn't think anything higher than an older E4400, or E4500 though.
The E4400, and the E4500 use an 800MHz Front Side Bus. So does the E5300 Dual Core.
The information box states that processors with Up To a 1066MHz FSB are supported.
I just don't know if there is a BIOS update needed, or if a BIOS update is available, in case it's needed.
Needed to change the voltage, and multiplier, so that a processor with a 1066MHz FSB can be used.
To summarize:
The ATI XPress 200 motherboard chipset, on your eMachines W3502, will support an Intel Dual Core E5300.
Advise:
Do Not forget to use anti-static precautions. Your body carries Static electricity. Static will fry out (Short circuit) computer hardware components.
A Processor is the most susceptible hardware component to static shock.
I would advise buying a cheap $6 ESD wrist strap, from some where like Radio Shack, or a similar store, and using it.
Clip the alligator clip to an unpainted surface of the metal frame, of the computer case. (Computer unplugged from power)
Barring this, make sure you touch the metal frame of the open computer case, before you reach inside. (Computer unplugged from power)
If you get up, and walk away in the middle of working on your computer, upon your return touch the metal frame again.
Make Sure the top of the Processor's case is clean, and the bottom of the Heatsink.
I use an old credit card to scrape both surfaces as clean as I can, then follow with Q-tips dipped in Isopropyl Alcohol.
Usually takes a few dipped Q-tips, as thermal paste is a gooey mess, and the alcohol takes time to break it down.
Isopropyl alcohol is also referred to as Rubbing Alcohol. 91 percent is best, but 70 percent will do. Nix on the 50 percent.
CAUTION!
Isopropyl alcohol is Extremely Flammable! Use in a well ventilated area, with no sparks or flames present.
Use fresh, new thermal paste, never try to reuse old thermal paste, or a thermal pad. Thermal paste properties break down over time, and the thermal paste becomes more of an Insulator, than a Conductor.
Thermal pads are only good for taking off, and flying at the cat.
They're Junk!
(Meooow! Hey watch it dude! You almost hit me with that!)
Thermal paste doesn't have to be Artic Silver 5. A good quality thermal paste, applied correctly, will get you down the road just fine. A 'Mom and Pop' computer repair shop, should have a one processor tube, for around $2.
You Should be okay with the same Heatsink/Fan combo, as the Intel Pentium Dual Core E5300 puts out less heat than a Celeron D 352, or around the same amount.
Be sure the inside of the computer sparkles, as well as the Heatsink, processor fan, and the inside of the Power Supply. Use a can or two, of compressed air for computers.
(Celeron D's are not dual core processors. The Pentium D's are)
Testimonial: "thanks... really hepls..."
SOURCE: sir which site i can get my driver software for
hi try this site
hope it helps
You can download the motherboard
drivers from Intel WEB site. Select your model motherboard/device, and make
sure you select the Windows XP or Vista version of the drivers that matches
your Windows operating system.
Please click on this link and
select your model motherboard : -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
What is it you are trying to download?
i want to download pictures,stories,or web pages
