Question about Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range
New Heating Element; Has Power But Not Heating Up
Convection oven kitchen aid superbra, replaced old heating element and was working, but recently stopped working. Tested power supply, when it heats up, it stays on low mode and does not get hot. Shows no indication of going higher; is it a bad heating element or something else?
  • 1 more comment
  • jon smith Nov 24, 2008
    my left font burner switch has burned up wires like a blown fuse or circut.these wires are black and orange or red . altough my burners work yet my heating elemnt is good,would this be because of the switch or bad mother board ?
  • jon smith Dec 01, 2008
    I think it is my thermostate ? yet I have two oni bad reads zero will this work? help
  • jon smith Dec 05, 2008
    error codes come up F2/E1
    what do these codes mean?
  • 833 Answers
Let's go over a few things:
  • Your unit uses 220 volts to provide heating.  Some elements are wired to one of the two 'legs' of the 220 giving you 'low'.  High uses 220
220 consists of three wires...two 'hot' (red and black) and a neutral which is white.  Neutral to hot will give you 110...hot to hot 220.  Measure accordingly and use care!  Neutral and the frame of the stove are effectively the same terminal...for safety.
  • You say some of the wires are burnt or a fuse is blown.  They need to be replaced with proper wire...not just any kind.  There is high temp insulated wire available from many ACE and other home stores or parts shops.  It needs to be thick enough, too.  Make all connections carefully and fully onto clean terminals.  Tighten clockwise.
  • Check the voltage coming to the element on various settings as above.  If you only get 110/120, you have an open supply issue which needs to be found.
Look for: loose wires, corrosion, burned insulation to ground.
Posted on Dec 04, 2008
My convection oven ring does not work
These tend to crack and "unzip" because they are such a tight circle... Kill the power, and meter the ring element for ohm's resistance. If the element tests ok, check the wires to the element for overheating, and if those look fine, remove the control board and look for burnt solder joints where the relays are mounted. Multimeter DM10T
Feb 22, 2015 | KitchenAid Kitchen Aid KEBS177SBL Single...
The preheat light flashes on my he range and oven does not heat. I have had the sensor checked and its working. What else could it be?
Most likely the heating element is bad. Disconnect the oven from power. You can open the bottom of your oven to expose the heating element and see if there are any signs of burns or melting. If you can, remove the heating element and use a volt/ohm meter to check "continuity" across the element ... it should be a dead short. While performing this inspection, confirm that the wires and connectors leading to the heating element are intact and connected.
Oct 28, 2014 | GE 30" Self-Cleaning Freestanding Electric...
My kitchen aid "superba " convection oven is not maintaining it's temperature. It has only one heating element on top.
There is a good chance there is a hidden element on the bottom. This is common on higher end ranges. It could be a bad element.
Sep 28, 2014 | Kitchen Ranges
Element in oven sparked at corner and now will not heat
The heating element burned through -- it needs replacing. Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element. To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 08, 2011 | Maytag MER5552BAW / MER5552BAQ /...
Our oven won't work. it is a convection oven, and it won't heat at all. the stovetop does work, but when we turn the oven on it says "low" and never heats up. the fan does turn on when we try...
Hi
If the fan is working then most likely it is the heating element gone bad.
You can check this if you have a multimeter or continuity tester.
Replacing the element is not too difficult, you have to get the back off, disconnect 2 wires, undo the fixing screws then fit the new one.
Don't forget to turn the power off first tho'.
Dec 17, 2010 | KitchenAid KESC307 Electric Kitchen Range
Convection stopped working a couple of months ago, now regular oven does not come up to proper temperature, top element is red bottom element is not
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 12, 2010 | KitchenAid KESC307 Electric Kitchen Range
Heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Jan 07, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range Logo
326 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
