Question about LG Dryers
I have a washer/dryer model number WD-1488RD with no apparent lint filter. Lint gets on the clothes.lint rings the grey rubber gasket around the doorand gets under the gaskets and around the rim of the steel drum where i can only reach it with long nose pliers. I wipe everything I can reach offf after each wash. Its still under warranty.
  • blackanar Nov 19, 2008
    I don't intend to pay to be told to use the warranty!!. Please give me an answer as if it were not under warranty
    thank you for the advice to soak with vinegar- I wil try that. The tips about cleaning lint filters were not useful as my model does not have one
  • 147 Answers
Your dryer should have a lent filter on the top our the inside of the dryer if not then it is built in an has a manafacter problem and should be taken back to dealer where you bought it from if under warranty still hope this help sincerly josh
Posted on Nov 19, 2008
    Genius:
  • 1,550 Answers
Its good that it is under warranty .
Go for it . Under warranty period dont try anything .
  • 1 more comment
  • SAM ANDERSON Nov 19, 2008
    Sometimes a lot of suds in tub will cause this cause lint and suds stick to the outer tub and is difficult to remove try filling the tub with hot water and use vinegar in the water half bottle let it stand for 5or 6 hrs .
    Now drain the tub it should work.
    Tips to keep the lint off the clothes
    • Clean the Lint Filter inside the dryer, before putting clothes inside.
    • Put your wet freshly cleaned laundry in the dryer (should still be moist).
    • If garment usually has a lot of lint, best way is to dry garment on
      its own inside out this way no lint gets on any other clothes.
    • Put a dryer sheet (prevents static build up) in the dryer, two if
      you like to overload your washer and dryer or are cleaning a comforter.
    • Set your dryer as indicated by the manufacturer of your clothes.
    • Let the dryer do the work.
    • Clean the Lint Filter again, after you have pulled out your clothes and secured them.
    The source for above information Wikihow.com
    If you have any other queries feel free to ask .
  • LG Master
  • 4,806 Answers
Do not try and fix the problem, if the machine is still under warranty, get it back to them to sort out!!
  • Lee Hodgson
    Lee Hodgson Nov 19, 2008
    trying to fix the problem yourself could result in your warranty being "void" don't take the chance when you can get the problem sorted out for free
    best regards
  • Lee Hodgson
    i'm sorry we cannot do that, if you remove just "1" screw then your warranty has been voided and you will end up relying on us to sort the problem at some possible expence, not just on this site but parts and service, etc.
    It is not recomened that you do not do that when the item is still covered by warranty.
    what you need to do is use the warranty to get the problem resolved.
    when under warranty a "quick fix" is not answer!!!
Where is the lint filter on Speed Queen...
You didn't say if it was top or front loading and did not include a model number. The model number is usually on a tag that is covered by the lid or door.
As far as I know most washers do not filter out lint during the wash but rely on the lint being suspended in the wash water and expelled with the dirty and rinse waters. Many do have filters in the drain that do need to be cleaned at times but the symptom is usuall a slow drain or not draining.
How to Avoid Lint on Clothes from Your Washing Machine Top Load Washer...
This is an active lint filter machine.
Filter Flo Lint Capture
At this link you can download Speed Queen Product Manuals.
Maintenance Tips
Front Load Washer Troubleshooting Lint
Oct 16, 2014 | Dryers
Tip
How to extend the life of your front load washer?
hello, i am Marclavoris your guru today with some tips to extending the life of your washer and your dryer. These are just some tips that will help you.
First of all for all of you front load washer users, many times i get many customers who after several uses of their front loaders, they smell mildew and a musty odor. This is due to the front rubber gasket being saturated with water or standing water, to prevent this from happening always wipe the front door gasket down or leave the door crack after usage.
I have notice that people use alot of fabric softener sheets, sometimes the clothes will push the fabric sheets down into the lint filter housing which could eventually cause clogging of lint or the static will cause lint to pile on top of each other accumualting a big ball of lint, which in turn will cause your dryer to take a long time to dry and may blow out a dryer fuse.
on Jan 04, 2010 | Washing Machines
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
How do I clean gw711 lint filter
There is no lint filters in these machines,
It is automatically pumped out with the drain water.
WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimize creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3
Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus
detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Jul 09, 2012 | Fisher and Paykel Washing Machines
Lint filter on LG DLEX2901V sticks up in the corner and catches clothes
Look familiar? LG dryer model DLEX3250W. Lint frame does not fit the slot anymore. NOT BECAUSE OF EXTRA LINT it's because the frame is warping.
Dec 07, 2011 | LG DLEX2901V Dryer
The dryer is heating but clothes aren't drying. There isn't much lint on the filter and the inside door and lint area is damp with wet lint spread around that area. It is a MDE5500AY model. Serial...
This just happened to us a couple of weeks ago, and we called a repair man. I might be able to save you $45 for a service call. In our dryer, the lint can fall out of the lint screen and clog up in the back of the dryer. Remove the back of the dryer (you might have to unscrew the lint screen too) and the ductwork inside the back (it's quite easy, I've now done it since my daughter dropped my sunglasses down the lint screen hole) just keep an eye on your screws. Remove the trapped lint, and vaccum out the hose, making sure there's no kinks in the hose as it runs to your house exhaust. Put the dryer back together and see if it works. If not, you've got a fan problem and will need a repairman. But apparently this is the most common dryer problem and will take about 20 minutes of your time to straighten out.
Nov 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How do we clean the dryer 's filter?
I think I know what you mean - the machine itself does not have a lint filter and over time I've noted that it can build up around the large rubber door gasket. You will simply need to be more fastidious about cleaning it out after each cycle. I've had success using an old toothbrush dunked in some water to get the stuff out. The washer's filter (located in the lower left corner of the machine) only traps large solid debris. Hope that helps!
Jun 26, 2009 | LG WD-3274RHD Front Load Washer / Dryer
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Lint vent
There is no lint filter in this machine, however, the condensing duct and condensing bellows can get be a problem later on if it gets jammed up with too much lint.  If you notice that it takes 50% longer or more to dry your clothes, you will need to have the duct checked and cleared out of excess lint buildup inside.  Not an easy job but it can be done.
Nov 28, 2007 | LG WD-3243RHD Front Load Washer / Dryer
Dryers Logo
24 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
