Question about Xerox WorkCenter PE120i All-In-One Laser Printer
Xerox WorkCentre Pro 215 E2 Error Code
I have a Xerox WorkCentre Pro 215 All-in-one printer that refuses to work. When it is first turned on, it flashes "E2" about 4 times then the codes reads F and 9 alternately. Also the panel displays the paper jam symbol (two rollers with a zig-zag line in red) flashing. If I use the clear-auto-clear-auto-14-enter, E and 7 alternately flash, but the red jam light is off. I have searched for any residue of paper in the path without finding anything. I even removed the fuser to look and found no paper residue. Any suggestions?
  • sinkk Feb 16, 2009
    I've tried running card stock through my printer and the E2 error will not go away. Other suggestions?
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
ERROR E2
Hi
You need to replace scaners belt mechanism
Nov 18, 2010 | Xerox WorkCentre PRO-215 All-In-One Laser...
I have a workcentre pro 215, this have a circle red light on, somebody could help me? thanks
That is the signal to reaplace the drum cartridge. It has a life of 18-20 thousand pages and then that light comes on meaning it needs replaced.
Mar 08, 2010 | Xerox WorkCentre PRO-215 All-In-One Laser...
I have a H3 error code on a xerox workcentre Pro 215. What do I do to clear it?
This should correct it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Dec 15, 2009 | Xerox WorkCentre M20i All-In-One Laser...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
J3 error On Xerox WorkCentre Pro - 215
A J3 means the toner cartridge is not compatible. That is the what the J3 message means.
Make sure the correct cartridge has been installed. For example, a Pro16 Toner Cartridge looks very similar and will fit in the machine, but it will display a J3 fault. Install a known correct Toner Cartridge if you suspect the cartridge in the machine is the problem. If the wrong Toner Cartridge has been used, the correct cartridge needs to be ordered and installed in the machine
It is possible the chip on the back of the cartridge is bad. Have you tried reseating the cartridge? Maybe it is just loose.
Dec 19, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
J2 Error ? Xerox Pro 215
J2 means your drum needs to be replaced. The life of the drum is expired.
Mar 13, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Xerox Workcentre Pro 215
This should resolve that fault code
Jan 24, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Xerox WorkCenter PE120i All-In-One Laser Printer Logo
672 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
