Question about Home
My whirlpool bath tub has three jets that work & 3 jets that are
Acting like water intakes(suction)
  • Canthony1 Apr 06, 2009
    I have all but 2 jets working. I tried what I found on one site, and altho it did not fix the problem, it helped. Fill the tub with hot water to above the jets. Pour in drain clog remover. Leave in 15 minutes. Drain and fill with cold water for 15 minutes to rinse. You would not beleive the **** that was in the tub! It was so gross, the jets and filter had to be clogged with a little of every bath product the kids have ever used. I am going to try it again! Altho they are all not working, they may after I do it again! The ones that were working are alot stronger!!
  • Rod Kidman
    Rod Kidman May 11, 2010
    I don't understand the problem. Can you clarify what is wrong or does not operate properly?
  • 125 Answers
The suction IS the water intake. it takes the water from the tub into the pump and the water comes back out through the jets.
Posted on Feb 24, 2009
Where the filter is located
There are no filters on jetted bathtubs. There is a screen with dozens of holes located in the footwell of the tub. that is the suction cover. the water flows through that screen into the front of the pump and then out through each of the water jets.
US Parts Center
Aug 21, 2013 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Kohler whirlpool type tub will not pump water out of its jets or take water into the intake. Pump appears to operate fine. Water does not want to move. Suggestions?
When a bath pump turns on but does not move any water it is usually because there is an Air Lock and needs to be released.Try this.
  • Fill the tub with water
  • Turn the pump on
  • Unthread the discharge pump union until water starts to squirt out
  • when this happens you should hear a big 'swoosh'
if the bath pump starts to discharge water through the jets then you have solved the problem.
Rod
us parts center
888-521-6183
Apr 05, 2013 | Kohler Home
I want to replace the 5 jet covers and suction cover for my Spurlin whirlpool tub. Where can I get replacement parts?
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: sales@uspartscenter.com
Mar 09, 2013 | Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
I have a jacuzzi tub in my master bath, and it has started surging through the jets in about an 8 second interval. Also I have started noticing a little bit of water leaking from under the side of the tub....
Surging is caused when the pump doesn't have enough water to push to the jets. this is usually a problem caused by air being drawn into the suction of the pump.
take a look at the jet(s) facing the suction cover.
I have seen cases where the water with the air mixed in causing bubbles gets sucked into the suction of the tub and causes the surging because the pump is pulling in too much air.
try rotating the nozzle of the jet facing the suction away from it. point it another way. turn the air control knob closed and see if that is the problem.
the only other issue that could cause this 'surging' problem is a leak in the suction line and could be the source of the water you see under the tub.
Aug 18, 2011 | Home
I need the manual of how to install the bath for the Comet 10 Jet Whirlpool 1500 x 1000 Bath. The Installer is having problem in getting the pump in the right position to work.
i don't have a solution for the manual however, the pump needs to be installed such that the bottom of the suction line going into the pump is 1/2" higher than the bottom of the suction elbow (coming out of the tub) thereby providing the pump with a flooded suction. This will provide the pump enough water to start pumping to the jets.
Feb 10, 2011 | Home
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
What is the round filter like attachment with tons of little holes on the inside my tub and how do i clean it
It is called the suction intake- the pump sucks the water in through the suction intake. It serves as a hair and particle trap (safety device). Some suction intakes can be unscrewed counter-clockwise, others have a round cover that can be popped off with a flathead screwdriver (the cover conceals a philips head screw).
don@crownbath.com
Dec 11, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Clogged suction line in bath whirlpool
It sounds like something got sucked into your pump impeller, you can try sucking it back out with a wet vac but my bet is that you'll have to open the pump to clean it out. If the marble skirt is the only acccess to the pump it will need to be removed but look for another way first, they can be difficult to reinstall and make look good. If your careful, the pumps can be opened and cleaned without much trouble, Use your wet vac to suction anything left out of the pump suction line and make sure the pump discharge and distribution lines are clean as well. Pump case should have an "O"Ring seal that should be replaced but may be cleaned, lubricated and reused if not dammaged
Good Luck, this is the kind of job the service tech's make there money on.
Oct 14, 2009 | Whirlpool ROYAL BRB909 Corner Tub, Jacuzzi...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Home Logo
651 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
