Question about Sub-Zero 680 / S
Service light is blinking & rubber trim is hot
Also hot to touch is center divider. The temp. gauge for freezer is flashing & changing.
  • 41 Answers
Usually when the center divider is hot to the touch, it means that the compressor is running hot. either your compressor fan is not running or it is stuck or running too slow. Joe
Posted on Nov 19, 2008
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Refrigerator quit working, power to compartment lights OK
If this is an American model refrigerator I will need to know the model number to see what may be happening. Can you post the model number? Thanks Sea Breeze1_10_2013_2_30_52_am.jpg
Jan 10, 2013 | Refrigerators
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
The divider between the freezer and refrig is very hot to touch.
Normal for that strip to be warm since the cooling system is routed right behind it for heat transfer and to eliminate condensation. Will be warmer with increase in room temp, but if it is a significant change you should inspect/clean the coils behind the panel in the rear of the unit.
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
97 saturn sl2 temp light flashing and low coolant light flashing what could be the problem ? coolant is full and the heat works.
If the temp gauge is reading normal, the lights are flashing, and the coolant level is full, the level sensor in the coolant bottle is the problem. I'm a service consultant for a Saturn dealer and I've run across this many times.
Apr 17, 2009 | 1997 Saturn SL
Freezer and refrigerator are not cold enough.
you problem check and see if your fan condeser working best call service
Mar 22, 2009 | Kenmore 53092 / 53094 Side by Side...
Possible fire hazard
we have same one ours gets warm but not hot enough to discolor you better call for service immediatly definate fire danger good luck
Mar 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Please can you help why only after about a mile the engine is red hot but temp gauge is only showing middle. is this normal. YEAR 2001 WITH SERVICE HISTORY ONLY HAD SIX MONTH.
When you say "red hot" do you mean actually glowing? If so, you'd have serious trouble. If you mean only hot to the touch, that's normal - these engines run pretty warm. And yes, the gauge in the center is normal - the OEM temp gauge is a dummy gauge, only meant to show you that it's either cold, overheated, or mainly OK. Use your oil temp gauge as your main indicator - at least it's graded numerically and you can actually see the oil temp.
Jul 16, 2008 | 1999 Audi A4
Refrigerators Logo
479 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
