Question about Toshiba SD4980 DVD Player
Red picture We had dvd hooked up to plasma tv with rbg cables and it was working fine. After adding home theater system we now have a pink and white picture when using the dvd, all connections stayed the same.
SOURCE: S-video imput not working
I had the same problem. Solved it by going to Set Up, Video Selection, then choosing the S- Video input jack, vs the default. Now if I could just get it to pass video when the unit is off...
Posted on Dec 28, 2007
SOURCE: Red Screen
i have the Toshiba A1 and a benQ W9000 projector. I never had this problem with my Sony HS60. I switched the video from 1080i to 720p and then back to 1080i and it fixed it immediately .... its really annoying though
Posted on Feb 08, 2008
SOURCE: No picture, but sound
Thanks - worked for me :)
Posted on Aug 03, 2008
  • 240 Answers
SOURCE: tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Posted on Jan 11, 2009
  • 1511 Answers
SOURCE: Connected DVD Player to TV using HDMI cable doesn't work
Have you changed the input of your TV unit to AV1, AV2 or component...or what ever? If so and yet the problem prevails, then try to Plug the AV cable to the input of your Cable Box, if it has so.
If i was helpful, kindly do Rate!
Posted on Jul 21, 2009
SOURCE: I have an old DVD player from 2002 & I'm
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Posted on Feb 07, 2010
0 characters
1 Points
Phillips 50pfp5332d/37
take it back and exchange it...then you'll know for sure if they are incompatible or TV is on the fritz or a bad sound system
Jan 14, 2014 | DVD & Blu-Ray Players
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo DVD & Blu-Ray Players
I get sound but no picture when playing a DVD
You only need the patch cord hooked up, For it to work,Not both.Allso you have to set your tv to the right in put to get a picture.If your DVD End tv is newer With blue end green jacks on it where they connect up.You will need a new patch cord with Blue end green plugs on it, The old style red white & yellow will not work.
Oct 17, 2012 | DVD & Blu-Ray Players
Hook up
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
just either use rca jacks from the dvd to the tv,,u know ..the red,yellow,and white cables,,,,that will do it,,,using the rca jacks ,,make sure to set the the dvd/reciever settings to anolog
May 17, 2009 | Durabrand DVD & Blu-Ray Players
Red picture
Only thing I could think of is check your Pscan on your players make sure the correct setting is set for Progessive Scan and the other thing is a common Did you check the cables ??
Nov 25, 2008 | DVD & Blu-Ray Players
I have just purchased a panasonic scpt850 home cinema system how do i get the speakers 2 work with just my normal tv?
make sure the TV has audio out and hook these (red and white cables) to the Home Theater TV/Audio in in the back then select the proper input and enjoy TV
Oct 01, 2008 | Panasonic DVD & Blu-Ray Players
Dvd player only plays in b&w, and connectors dont seem to match up with tv
I had this problem too. I had to use the cables that have red white and yellow and the back of the dvd player had red whit yellow but also had another set of red blue and green. I had to hook white to white,yellow to green and red to blue and it fixed it. Hope this helps
Sep 09, 2007 | DVD & Blu-Ray Players
Inexpensive S-video cable is OK?
If you dont have a hi tech theater setup you could almost use jumper wires, BUT yes, the cheap on would work just fine and you would'nt notice the differance from the cheapo one to the expensive type.
Jul 23, 2006 | Panasonic DMR-ES25S Diga DVD Player and...
Toshiba SD4980 DVD Player Logo
20 people viewed this question
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
