Question about GE 32GT660 32" TV
Sound TV works great but when i turn the volume up it goes back down to zero every time.... This happened before and all i did was unplug it for 10 mins and it went away but this time that trick is not working... any ideas???
  • 55 Answers
I would guess you have a microprocessor problem. Not anything you'd be able to do yourself.
Posted on Feb 18, 2009
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
My plasma has lost volume, picture OK, turns on but not to standby and none of the buttons or remote changes anything?
First is to remove power from set and a box if used--the sound issue happened at same time? It sounds like the set locked up internally and if unplugging things does not help it may be a main board issue in the set.
Nov 05, 2012 | Televison & Video
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Sound won't turn down
Change out your audio cables ,if this does not work some where you are missing ground.or its not connected right.ThankYou for using FixYa. Have a Nice Day.
Feb 17, 2008 | Toshiba 51H83 51" Rear Projection...
Volume up then pic gone
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
Televison & Video Logo
41 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
