Question about Dryers
Whirlpool electric dryer
I have a whirlpool dryer model no.le9300xttwo changed power cord and it melted to terminal box .we put in another terminal box but forgot where the green wire this a ground wire and where does it go. any info would be appriciated .also this green wire comes out of dryer to the terminal box tks
  • 5,911 Answers
The following link explains how to wire an electric dryer:
This explains BOTH the three-prong and four-prong plug configurations, wire color codes, and the voltage readings. I hope this helps you. Let me know if you require additional assistance.
Posted on Nov 19, 2008
Discolored terminal on cord
Check the dryer power cord for any signs of melting or charring. It could just be a loose connection. Then.....
Check the wall plug - there's a possibility the wall socket is either worn or the wiring to the socket isn't tight. The socket will need to be removed to check this, so make sure the power is off first.
Mar 30, 2010 | Amana NDE5800AY Electric Dryer
Changing electrical Cord from a 3 prong to a 4 prong. I need a wiring diagram
black to black lug white to white lug red to red lug green to ground(any bolt that is attached to body of dryer)
Dec 20, 2009 | Whirlpool Dryers
How to change power cord on dryer
Shut off the power to the dryer and just remove the 3 or 4 wires from their terminals. Put the new cord on the same way you took the old one off. The white wire is neutral, the green is ground and the other two (hot) don't matter which terminal they go onto.
Nov 06, 2009 | Whirlpool Dryers
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer 4 tp 3 pring cord install
Hello wgirdler,
While it is preferred to upgrade the receptacle to a 4-prong type (which includes Neutral & Ground) Code requirements grandfather in 3-prong receptacles in older homes. So if your preference is to remove and replace the power cord on your dryer, make sure you get one that is designed for a dryer application and is 10/3 type. ( 10 Gauge wire with 3 conductors)...
Unplug the original 4 prong plug from the receptacle and pull the dryer away from the wall to gain access to the back of it.
Next, loosen the cord clamp that allows the cord to pass thru the back panel and into the druer compartment.
Open the access cover to where the end of that cord is terminated on a terminal block of the dryer.
Note which color is attached to which terminal ( red to red,black to black, white to white and green to green)...
3 Prong cables do not use a ground wire ( green) in the cord so you would wire the red to red, black to black and white to white ( The red and black are the power conductors and the white ..which is normally terminated between them.. is in the middle. You can get a seperate insulated conductor wire and route it from the ground stud of the dryer to the receptacle metal casing but do this with power disabled at the circuit breaker box...
Hope this helps.
Nov 29, 2008 | Whirlpool LER5636P Electric Dryer
Burning smell
Hello benson131,
Based on your description, you already identified the problem as being a bad power cord. There is a high probability that the place where that cord is wired into the back of your dryer that the terminals worked themselves loose. Loose terminals become resistive and do not allow adequate current flow to maintain dryer temp so more current is required and that additional current will cause the insulation to melt on your power cord. I suggest you do the following. First off, unplug that cord from the wall recpetacle. Determine if you have a 3 prong or 4 prong plug. Go to a local home goods store like Home Depot or Lowes to get a replacement cord set that matches the one you have.. ( probably cost between $10 - $15 ) Once you have the right cord.. pull the dryer out and away from the wall.. Locate the feedthru on the back of the dryer rear panel.. ( that is where the cord goes into the dryer) and usually has some kind of cable clamp to keep the cord from being yanked out of the dryer.
Loosen the cable clamp and then look for an access panel where the wires physically get tied into the dryer. Once you have the cover removed, you should see a terminal block with 3 or 4 positions and color coded ( red/ white/ black and or green.. ) the Green is a ground wire and may be secured to a frame stud and not on the terminal block. Unscrew the wires from the old cord and reinstall the new cord in its place. Make sure you match the colors correctly ( red to red, white to white,black to black and green to green if it has a green position of green to a frame screw.) Make sure these wire terminations are reasonably tight. Once together, put the cover back over the terminal block and make sure the cable clamp is snug. Then plug it in and run it.. Your problem should be resolved.
Let me know if you have any questions with this...
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
Your issue is as follows;
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 17, 2008 | Whirlpool Dryers
Dryers Logo
102 people viewed this question
Top Dryers Experts
