Question about Mitsubishi WS-55411 55" Rear Projection Television
Code 22, will not power up.
The set was left on for several hours and turned off by itself. Unit will turn on for a few seconds and then turns back off. Pressed the input and menu buttons and retrieved a code 22. I have tried to research this code but I am coming up empty handed. Can anybody point me in a direction?
I would also like to find a service manual for the set(either hard copy or download), can anybody suggest a place to purchase one.
Thanks in advance
  • Jeremy Elenbaas
    Jeremy Elenbaas Nov 19, 2008
    I downloaded the PDF, but for some reason not one of my computers can open it. I even updated acrobat on all of them.
    Thanks for the link though.
  • Jeremy Elenbaas
    Jeremy Elenbaas Nov 21, 2008
    Send it to jcaelenbaas@hotmail.com Thank You very much.
  • 72 Answers
I found you a manual :)
http://www.mitsubishi-tv.com/support.html
from here select
CRT televisions, year:2003, then your model, and click pdf :)
Posted on Nov 19, 2008
  • Erik Lindebrekke Nov 21, 2008
    do you have an e-mail? the way the site is set up it tries to immediately display the PDF before letting you download/ save it to your own hard drive, your PDF viewer on your comp just might not be able to process it right like that. I have the whole file on my comp (all 79pages, over 4mb)...I can send it too you in an attachment if you'd like
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
Feb 22, 2013 | JVC Lt22em72 22-in Led 60hz 1080p Hdtv
Sharp 80le632u lcd turn off randomly & suddenly
Checked Power Board is it any solder is not proper. Resolder all main point.
Jun 04, 2017 | Sharp Aquos Televison & Video
Washer won't turn on at times. It acts like it has no power. Unplugging electric cord from wall socket and reconnecting seems to reset the unit and it functions normally for a while. After an hour or...
Try this first, unplug the unit and connect it to a different outlet and see if it corrects the problem. If it still continues, you will need to replace the control board. Good luck.
Jun 18, 2011 | LG WM2301HW Front Load Washer
My screen turns off and on... stays off for several seconds and thens turns back on... does this several times, then wont turn back on until I unplug the power cord and replug.??? Unit is about 1.5 yrs...
Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com
Jan 20, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
Overload light on Aims 5000w inverter
try to disconnect all cables from front and back, then turn the unit on and let all the stored charge drain and reconnect and test...make sure the unit grounded
Sep 06, 2009 | Inverter AIMS Power 5000 / 10000W
Air conditioner turned itself on to 22 degrees.
If it got to 22 degrees the Ac unit should have self destructed. What brand and model is that unit?
I think I would love to have one here in Georgia.
Aug 21, 2009 | Royal Sovereign ARP-4012 Portable Air...
Tv powers off and on after operating for about 1 hour
Same happened to me with my old panasonic set. It was a dry-joint. You can try re-soldering the circuit.
Good Luck.
P.S. - Check the Power Suply area closely.
Feb 20, 2009 | Hitachi 60VX915 Rear Projection Television
Digital TV Converter keeps shutting off
The DTA800 has a Power Saver feature that turns the unit off after 4 hours if it is idle (no volume or channel changes).
Press MENU button, press #5 (Setting/Configuration), press #3 (Power Saver) Select OFF to de-activate this feature (no Power Saver).
This is covered on page 11 of the DTA800 user manual.
Apr 25, 2008 | Televison & Video
RCA Colortrak plus. Model# F32672SB Serial # 807560570 Chassis # CTC187CJ3 Manufacture Date Feb 1998 Service # F32672SBFM3 4/21/08- TV worked fine last night. This morning worked for about an hour. ...
It's probably a cracked solder joint in the power supply / horizonal drive stages. As the unit heats up the joint is seperating and breaking connection. It could also be a component failing when it gets hot. Usually the voltage regulator or Horizonal Output Transistor (both mount to heat sinks).
If you know how to solder and want to tinker, unplug the set for a couple days (to let the power capacitors discharge) and resolder and crystalized it cracked joints on the board(s) where the power stages, and flyback transformer are located.
If you decide to operate the set with the back off, please be careful. The high voltage on a TV can be 30,000+ volts.
Hope that helps,
Geno
Apr 21, 2008 | Televison & Video
The flashibg red light
John, I do not know of a code, but it is a good idea in the design to have several goes at starting a circuit, before completely shutting it down. Oscillators are supposed to self start due to noise generated. Some electronic circuits require a reset pulse to be generated before the start up is allowed. The reset circuit may not be generated if the set is turned on again too soon, so it will stay in standby. This may normally be a few minutes to 30 minutes so it seems something in your set is faulty and could get worse. Try a test run with the back off and clean it out of dust with a long brush to keep it cooler. Make sure little fingers cannot get near it. Look to see if anything is obviously overheating.
Oct 21, 2006 | Thomson 24WK25U 24" TV
Mitsubishi WS-55411 55" Rear Projection Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
