Question about Philips 51PP9910 51" Rear Projection HDTV
Philips rear projection HDTV
When the television is turned on, a bright green color is all over the screen with a sort of rainbow shaped line that moves up and down. This goes on for about 10 seconds and then the screen goes black. Any idea what could be causing this and how much it will cost to fix?
  • missiecsmith Apr 26, 2009
    tv is showing the same red and green
    Problem Solver:
What should i do
Posted on Apr 26, 2009
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Whites are real bright and has an orange color
Hi my name is Eric,
I can help you with your issue ,
 This philips TV could have a number off issues, fluid leaking from a CRT,
or the SSB or SSM boards are bad.
I tech will charge you over $350 to replace a board.
There are color adjusters in the back inside the TV , red blue green screen controls, it wouldn't solve your issue , but lowering on may make it watchable for now
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 07, 2009 | Philips 60PP9202 60" Rear Projection...
Screen has too much green all of a sudden
Try balancing the tubes out, turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Sep 03, 2009 | Hitachi 57F500 57" Rear Projection...
Red green lines across my screen on 51 inch tv hdtv
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Jul 20, 2009 | Philips 51PW9363 51" Rear Projection...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Green color screen
your hdtv cables are wrong color match them to the input on tv
Nov 09, 2008 | Philips 55PW9363 55" Rear Projection...
Green on screen
try to do it inside the board.
there are some adjustments except brightness and focusing..
try if you can ...
regards,
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 51PP9910 51" Rear Projection HDTV Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
