Question about Citizen Eco-Drive BL006056H Wrist Watch
Corrosion hi, not a citizen watch, but what causes a watch to corrode so much that it can get an edge enough to cut and/or scratch my arm? i have timex now, stainless and the underneath edges and the stem are scraping my arm, watch is only about 8 months old. thanks for any insight, have always had this problem with watches, any suggestions i.e. titanium etc. glen chapman gchapman@royell.net
    Champion:
  • 203 Answers
Sounds like the acid level in your sweat is high a lot of watches onlly have a light plated skin over base metal. if you look at whats scraping you you will see the edge of the surface metal and the base metal . if this helps please rate.joe
Posted on Nov 22, 2008
Keeps good time until I start to wear it?
your electricity in your body does it,it happens to me too,also,pure stainless steel corrodes on my wrist
Jul 09, 2015 | Citizen Watches Citizen Elegance Signature...
How to change the battery?
Use a knife to lift the case back off, there will be a spot to get the blade under it. Take care not to scratch the case or back. Once inside you will see the watch movement including the battery, you will need to use some pointy tweezers to carefully move the small arm which holds the battery in place, be very careful and gentle. Replace with correct battery, using your tweezers so the acid from your skin doesn't start any corrosion later on. You will have to hold the small arm back to get the battery back in, it should go in easily so don't force it. Line up the back of the watch so the small cut out is on the same side as the stem and crown (winder) Push the case back down applying even pressure taking care not to push against the glass on the other side. Make sure it is making contact all the way around. Set the time and you are done. If in doubt take to your local jewellers or watch maker, as it is only a cheap thing to have done professionally. Good luck
Oct 01, 2013 | Kenneth Cole Mens Leather Date Watch...
To whom it may concern. I would like to know the size of the Eco Drive Citizen C650 watch. Thanks.
There is not enough information given. Citizen is make. Eco Drive is patented micro electric system name. C650 is caliber number. C650 is fitted in to many Citizen watch models. Give us exact model name, numbers, serial, etc. - then we can give the size. For a while you can check out C650 here: http://www.citizenwatch.com/COA/English/settingsresults.asp?caliber=c650 Citizen watches here;
Feb 27, 2011 | Watches
How is the case dimention of a wrist watch measured......what is all is included?
If you are looking to purchase a new watch, you have likely seen that there is a measurement for the watch case. This does not mean the box which contains the watch. The watch case is the space between the two arms that extend above and below the watch where the band attaches. The end of the band will fit in between the watch case. You will need to know this measurement both in purchasing a new watch and in looking for a replacement band. Often, watch makers give this number in millimeters, and for that reason, you will need to use a metric ruler to make the measurement.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
  1. Find the watch case. It is the space where the end of the band attaches to the watch face. Refer to the image for a picture of the location of the watch case.
  2. Using the metric ruler, measure the distance from the inside of one of the arms to the inside of the other arm. Watch makers use the inside measurement when creating their watches, not the distance from the outer edges of the arms.
  3. Write down the measurement on the piece of paper. Measure the other watch case, but they should both be the same measurement.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 28, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
How to recharge B023 ecodrive watch? Though I keep it long enough under light & do a reset, its time is still lagging behind.
hi, how long do you keep it under the light for?
Have a look at page 2 on this pdf file from the citizen website for more info on charging times.
http://www.citizenwatch.com/Technical/English/Full/B023_ebook.pdf
I hope this helps a little,
Regards
Mike
May 26, 2010 | Citizen Eco-Drive Silhouette EW869452D...
The glas of my citizen jr3060 has a big scratch on it,what's your opinion?
Go to stewarttime.com. I have had 2 of my Eco Drive watches repaired there. They do a great job with good pricing and great communication during the whole process.
Feb 17, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Eco Drive
Wind the arms around one more time because a analog watch clicks like a clock. Hope this helps out.
May 25, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen watch has scratched glass
Unfortunately, the only way to fix this problem is by changing the glass.
Thanks
Sep 12, 2008 | Citizen Eco-Drive Silhouette EW869452D...
Citizen Calibre 8651 - replacement parts?
The chrystal is scratched on my mens watch ,where can I find a replacement?
Mar 24, 2008 | Watches
Citizen Eco-Drive BL006056H Wrist Watch Logo
69 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
