Question about Olympus Camedia C-350 Digital Camera
Shutter will not close. Appears to be locked with shutter out. Slider is ok. Not batteries. Cannot take a photo. Nothing shows up on quick view. Red light blinks for a short time. Makes a beep sound. Then cuts off.
  • 114 Answers
It´s normal in that kind of cameras it can be fine but after u shoot one pic with flash will happen the same, to fix the problem u will need to send it to a repair centre, they will isolate some stuff inside to prevent that from happening.
Posted on Jan 19, 2007
Camera not working
Hi Jane,
When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder.
At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens?
Cordially,
Jul 25, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
Can't take any photo with my Canon S3IS any more. The view finder and the screen is black when I try to take some photo but I am able to see all photo that is already on my memory card in the view finder...
Look into the lense while setting the shutter speed at a half second or so (slow enough for you to see the shutter open and close) and click the shutter release... you should see the shutter open and close. If you don't see this, then you may have a 'sticky shutter' resulting from lubricant seeping into the shutter/aperature mechanism and preventing the shutter from functioning as it should.(Common problem reported with the S2 and S3 cameras... and probably the S1 as well)
I have gotten my S3IS to take pictures by turning on the power, then opening the battery compartment door and reclosing it repeatedly until the shutter opens (from the power surge) and an image appears on the LCD.
After confirming the sticky shutter was indeed the problem, I pursued a more permanent fix.
Jan 30, 2011 | Canon PowerShot S3 IS Digital Camera
I am having what appears to be a classic problem with the sx 70 after reviewing some forums. The viewfinder goes black when i push the button then nothing for a long period of time. Once i push it again...
How old is the battery? The shutter in all polaroid cameras ia battery controlled, so if the battery is old, the shutter will not function properly. If it's taking a while to make noise, rollers aren't likely an issue - roller issues are evident with spotte development. It may be an issue with the motor, shutter, or battery.
Aug 05, 2010 | Polaroid SX-70 Film Camera
My A540 clicks like it takes a picture but nothing shows on the display screen. When I take the memory card out and insert to computer the frame of pictures show but the photos are black.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
But if you do notice shutter movement, then this would then likely be a CCD imager failure. It would in that case require Canon service to repair (1-800-OK-CANON).
Nov 10, 2009 | Canon PowerShot A540 Digital Camera
IPhone camera stopped working
My iPhone camera stopped working.i press the cam widget and the shutter appears closed.
Sep 15, 2009 | Apple iPhone Smartphone
The camera shutter is always open
Plecs can you send me k750i Camera solution (with photos)
Oct 28, 2008 | Sony Ericsson K750
LCD Black
sorry I have the same problem. It seems like it is a shutter problem...the shutter is locked closed therefore the screen is black.
Feb 25, 2008 | Konica Minolta DiMAGE E500 Digital Camera
Menu and display buttons do not function
One quick question. Is the camera taking photos?? when you try to transfer the photos to computer , are the photos fine or there are some Black photos??
Regard's
Manoj Goyal, INDIA
+91-9214988557
Dec 03, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Black viewer and black photos
THE MOST LIKELY REASON FOR THIS COULD BE EITHER THE SHUTTER IS NOT OPENING(IN THIS CASE WHEN YOU HALF PRESS THE CLICK BUTTON YOU SEE SOME SORT OF SNOWY PICTURE )IF NOT THEN THE CCD HAS GONE FAULTY AND IN BOTH THE CASES THE HARDWARE NEEDS TO BE CHECKED THERE IS NOTHING YOU CAN DO ABOUT IT YOURSELF
Nov 17, 2007 | Fuji FinePix F20 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
50 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
