Question about Lexmark Office Equipment & Supplies
Printer cant set up spooler problem - Lexmark Office Equipment & Supplies
  • Lexmark Master
  • 4,338 Answers
Go to start/settings/control panel/Administrative Tools/services.
Scrool down to Print Spooler, set it to automatic.Then click the "start" button to start the print spooler service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 19, 2008
Cant start printer spooler error 1068
This is caused when there are still printer jobs in the Windows spool. To manually remove these print jobs follow the below steps.
  1. Click Start, Settings, Control Panel.
  2. In the Control Panel double-click the Administrative Tools and then Services.
  3. Within services locate Print Spooler and right-click it and select Stop.
  4. Once this process has been stopped leave the windows open and open My Computer and browse the the below folder.
    c:\windows\system32\spool\PRINTERS
    or
    c:\winnt\system32\spool\PRINTERS
  5. In this folder delete all the files in the PRINTERS folder. Once these have been deleted you can right-click the Print Spooler in the Services window and click Start to re-enable the service.
If this does not resolve your issue it's likely you have an issue with your printer drivers you have installed for your printers and/or you have a trojan, virus, or worm infected on the computer.
Dec 12, 2010 | Brother MultiFunction Center MFC-440CN...
Unable to delete doc after being sent to printer
First, I would try canceling the document either at the printer (hit cancel if it has already been sent) or at the computer.
You can do this by going to start -> settings -> printers and faxes
double click on the printer to open it
right click on the offending file and hit delete
It sounds like both of these have been done already. So...next option.
Second option - Restart the print spooler
Go to Start -> Settings -> Control Panel -> Administrative Tools -> Services
Click on the "Print Spooler"
Select Restart
Third option - delete the document from the spooler
Stop the Print Spooler by following the instructions above and clicking "stop"
Delete all files in the c:\windows\system32\spool\printers directory
Restart the print spooler.
CAUTION!!! - This will clear out both the offending job and any other jobs that have been sent to the printer after the offending job. If you have a number of other jobs, you may wish to clear out only the offending job from the printers directory.
Hope this helps - flub
May 29, 2009 | HP Officejet 4315 All-in-One Printer
My computer cant install printer as it says my printer spooler not working and i havn't got a valid port /driver..please help
Try this:
Open "control panel"
click on "administrative tools" (you might have to switch to "classic view" if it's not already set)
Click on "services"
Scroll down to "print spooler"
Double click on it
Under "startup type"...select "Automatic" (if it's not already.
Then under "Service status" Click "start" if it's not already started. If it is started, click "stop" then start it again.
Click "apply"
Close dialog boxes and try installing your printer again.
Please let me know if this helps :)
Apr 17, 2009 | Lexmark X1270 All-In-One InkJet Printer
Printer Spooler service!
This will provide you with the most common default settings.
  1. Restart (reboot) your system [to assure a clean reinitialized starting point].
  2. Log on as any Windows user that has 'administrator' privileges.
  3. Open your 'Services' console [Start button > Run... > type "services.msc" (without quotes), then hit 'Enter'].
  4. Locate, then open "Print Spooler" [double-click it OR right-click it, then choose "Properties" from the context menu].
  5. Modify the settings on the "General", "Log On", and "Recovery" tabs according to the following images.
"Today's the best day of my life...and NOW you're part of it!"
Dec 11, 2008 | Lexmark E120 Laser Printer
Printer spooler not working
Scrool down to Print Spooler, set it to automatic, Then press "start " to start the print spooler service.
Thanks, Joe
Oct 08, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark x3480
Try restarting the printer spooler in the windows service management console.
Sep 20, 2008 | Lexmark X3480 All-In-One Printer
Hp photosmart C3150
Hi it is the issue with the Print spooler
please refresh it :-
  1. Click Start, click Run, type command, and then click OK to display the command.com window.
  2. Type net stop spooler, then press <Enter>.
  3. Type sc config spooler depend= RPCSS start= Auto, then press <Enter>. The spaces between = and RPCSS and = and Auto are important. Without these spaces, the command fails.
  4. Type net start spooler,then press <Enter>.
Nov 17, 2007 | HP Photosmart C3150 Printer
Print Spooler Problem
Click on start
click on run
Type services.msc
A box will open up
Make sure all items below are set to automactic
To make the changes double click on each item
change to automatic if diabled. Then click apply when you are done.
Restart the computer and try testing your printer again.
Printer Spooler
LexBce Server
Remote Procedure CallRPC)
Hope this solves your problem
Oct 20, 2007 | HP DeskJet 670c InkJet Printer
Print spooler
Click on Start Click on run Make sure the run line is clear Type services.msc You will see a list of services Make sure all items below are set to automactic To make the changes double click on each item line change to automactic if diabled. Then click apply when you are done. Printer Spooler LexBce Server Remote Procedure CallRPC) Restart the computer Hope This helps
Sep 17, 2007 | Microsoft Windows XP Professional With...
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
