Question about Brother MFC 9600 All-In-One Laser Printer
Brother MFC9600 dirty printing
Brother MFC 9600 prints with big wide smeary black smudges running vertically, ttwo obscuring black bands 2" wide approx one inch from each L/R edge. Mulitple cleanings of drum, corona wire, and replacement of toner hasn't changed a thing. Here's the curiosity, the black thick deposited toner smears CLEAR WITH ADDITIONAL PAGES OF PRINTING. If I print a 10 page document, pages 1-3 are unreadable, 3-6 show diminishing black smears, and by 6-10 they are perfectly clear and normal looking white backgrounds.
What can cause this? It must be obvious to someone who understands how they work. I don't want to waste money on a drum only to find out its fuser, or on both only to find out its something else. A new printer is cheaper. Can you help, please????
  • maardvark Nov 21, 2008
    Thanks bethwood77 ...I'm aware that this may fix it, but a (new not refurb) drum (which comes c toner) costs nearly as much as the new printer with same functions and network connection. So, I'm afraid to spend on the drum and find the problem isn't solved, say its the fuser.
    Maybe I'll give it a shot.
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Posted on Nov 20, 2008
My brother mfc 7840w is printing black smudges on the edges.... and can see some residue from previous print. Please advise
The rollers are dirty and / or you tried to print on both sides of paper. Don't do that, it makes a mess.
Aug 18, 2014 | Office Equipment & Supplies
Edges of prints are black smudged
MAY BE DRUM UNIT IS END OR LASER UNIT
JUST SEND A COPY VIE MY MAIL SHAMMINOLTA@GMAIL.COM
Dec 14, 2013 | Brother MFC-8460N All-In-One Printer
How do I print in color & can I download the software off the internet with the brother mfc 9600 all in one
This printer only prints black. Down load drivers from brother.com Thank you, Steven 805-520-3003
Jul 08, 2010 | Brother MFC 9600 All-In-One Laser Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Brother MFC 7820N Smudging Concern
If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobellaâ„¢ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
Printing problems
If it is approx 3-4 smudges down the page. Replace the drum cartridge.
Oct 30, 2008 | Brother MFC-8460N Laser Printer
Need User Manual for Brother MFC 9600 All In One
Here's the link; http://www.amazon.com/Brother-MFC9600-Flatbed-Laser-Multifunction/dp/B00004U4A0 Under "product details". Hope this helps :)
Sep 11, 2007 | Brother MFC 9600 All-In-One Laser Printer
Printed pages look dirty
That black dust that fell out is the toner. When you shake a toner cartridge that shouldn't happen. It looks like you have a faulty toner cartidge and that need to be replaced! Now to make your printer prints cleanly and clearly after you replace the cartridge, you'll need to get someone to service the printer(the faulty toner cartridge more than likely spilled toner on your internal printer parts, cause the smudges). Sevicing would mainly entail, taking down the printer and removing any spilt toner! If you feel you are up to this, be cautious, because toner can be hazardous to your health if you accidentally breathe it in! hope this was helpful! regards babb
May 10, 2007 | Brother MFC-7820N Laser Printer
Improve print quality
If you have changed drum AND toner, and reset drum count, cleaned scan slit glass on lit then only other thing to clean that can cause dirty prints is laser glass, (remove drum, inside where drum goes there is a slit the rund width of printer on inside middle "ceiling"
The orange piece I take it is the lower heat roller at rear, cleaning this is not going to fix anything.. this area called the fuser sometimes the fuser wears the coating off the upper heat roller (above orange one) and leaves like a smudge mark on prints, like I say cleaning wont fix replacingfuser with new would be what is required
I find a lot of grey shading on prints on this model are from faulty toner cartridges, next is drum then worn fuser roller... Stop a print half way (timing) in machine remove drum and look at print, after drum but pre fuser ,to see if image is ok before entering fuser, then we know if that is your problem
Sep 20, 2006 | Brother MFC 9600 All-In-One Laser Printer
Brother MFC 9600 All-In-One Laser Printer Logo
655 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
