Question about Hoover Washing Machines
Washing machine 700lb will not wash with a full load
SOURCE: The duet washing machine fills up with water in between loads. What is Causing This?
Dont want to endorse a commercial site, but you can by a generic part for a bit over $10 for this problem, so do some seraching for a reasonable site (other sites are charging 40-50 dollars for a fill valve.
Posted on Aug 09, 2007
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
I have a front loading machine also and am not willing to have to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Posted on Aug 23, 2007
gdmisp
  • 66 Answers
SOURCE: washing machine
BELT NEEDS REPLACED OUR THE DIREC DRIVE NEEDS U JOINT.
Posted on Jul 03, 2008
milten1
  • 1304 Answers
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Posted on Oct 20, 2009
  • 97 Answers
SOURCE: Hoover 700LB Stops at the wash during the wash
It sounds like the timer is bad. Try another cycle like delicate, or normal, or heavy duty. If everything works on another cycle then it is probably your timer. If it doesn't work and you have the same problem, then it is probably an expensive fix. Best of luck
Posted on Mar 21, 2010
Hoover 700lb
Failure of the valve in the cold water inlet section., Remove and clean, back flush with high pressure and if there is no result you must replace. Check the valve winding to confirm if the coil /solenoid is working.
Apr 03, 2014 | Washing Machines
Unable to wash a full load
Run a "Washing Machine Cleaner solution" through your machine to clean out built up grime and dirt inside the drum.
You must of course always only load up clothes so that there is good space left for them to move freely. Jammed up clothing will never wash clean.
Use a really good detergent, and my tip is NOT to use fabric softeners as they really gum up the works and cause grime and dirt buildup in places you cannot see! This mucky stuff then finds it way back into the next wash and the next and so on.
Poppa
http://www.cdbaby.com/cd/poppamadison
Nov 13, 2011 | LG WM2277H Front Load Washer
Is not spinning and not completing a full wash cycle
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 23, 2011 | GE WBVH6240F Front Load Washer
Front load washing machine full of water and wont enpty or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 11, 2011 | Whirlpool Duet WFW9550 Washer
Washing machine is full of water but will not empty and spin
heatman101
Nov 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hello, my Hoover 700LB toploader won,t spin or agitate, the pump is working, but the motor is not working at all,
Hi just read your posting.Now the problem could be your motor or motor module.Have you got or can borrow an electrical test meter to test the motor and wiring? Please reply back and and I can guide you the finding of the fault and the repair.Also I will look at my manual to see if you can test for the fault without a test meter.Looking forward to your reply.
Aug 24, 2010 | Hoover Nextra HNT 2135 Top Load Washer
24632300 washing machine spins but not under full load. Will not ring out load.
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Kenmore Washing Machines
Hoover 700LB - fills as per normal and washes but cycle knob does not move, click or progress towards the next cycle therefore washes forever...timer perhaps and if so is it worth fixing?
Hi just read your posting.Does the timer move at all from the original position that you started it from?If it does not move at all then you need a new or reconditioned timer.If it does move but stops at a specific spot,What position does it stop at?Are you in Australia? If so I can give you the contacts on where to purchase a timer.Please reply and I can guide you on how to get the correct timer number for your machine.Looking forward to your reply.
Jul 24, 2010 | Hoover HTC243 Top Load Washer
Hoover 700LB Stops at the wash during the wash cycle keeps clicking then starts again at the spin cycle
Mar 21, 2010 | Hoover HTC243 Top Load Washer
Hoover 700LB top loading washing machine
there should be a wiring diagram on board in an envelope or taped somewhere you can get one from sears too
Dec 09, 2006 | Hoover HTC243 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
