Question about Car Audio & Video
4 error appears on Car Radio
We have a Citroen Saxo, and, after being serviced, the words "4 error" appeared on the radio, and it hence isn't working.
Does any one have any advice on this at all?
Many thanks,
Philip
  • ger3000 Dec 28, 2008
    me too except mine says 8 error!
2 Suggested Answers
  • 4807 Answers
SOURCE: I have lost the radio code for my citroen saxo
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also  has a BARCODE SERIAL NUMBER beginning with
C7000000 + + + +  on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If you have this barcode serial number then
POST ANOTHER QUESTION
If not then it will only be available from  your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM
Posted on Oct 13, 2009
SOURCE: citroen saxo radio code
iv got this program, and it states ur code is 2566. i hope this is correct for you
Posted on Jun 30, 2011
I need radio code for citroen saxo
im sorry but i think the dealer can only give you that code.
Jan 20, 2015 | 1998 Citroen Saxo 1.1
I need to unlock my car radio in citroen saxo, can u help?
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Jun 22, 2011 | Car Audio & Video
Need to find radio code for my citroen car part number gr0971w6815397
Need code for my Citroen Saxo GR0947W1709832
Thanks
Jul 04, 2010 | Grundig G4B AM/FM/SW/RDS Radio
I need a radio code for a citroen saxo dseire
Remove the radio from the dashboard.
Then post the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS , BARCODES or STAMPED IN THE METAOL CASING
Jun 26, 2010 | Car Audio & Video
Radio code missing
Try code 6 2 2 4
Jun 07, 2010 | Car Audio & Video
Stereo code for Citroen Saxo
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7 000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
May 15, 2010 | Car Audio & Video
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
Mar 29, 2010 | Car Audio & Video
Citroen saxo radio code
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING.
Make sure you quote EVERYTHING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Oct 02, 2009 | Car Audio & Video
Car Audio & Video Logo
223 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
