I've tried changing a few settings as suggested by Microsoft message boards but nothing I have done will get it to turn on. I am using Vista 64 bit
SOURCE: vista and microsoft office word 2007 cant paste and copy my image
These file types are supported: click here. & corrupt?
Please see the following links and see if this doesn't lead you to an answer for your question....click here.
Also Clip organizer, insert clipart, copy clip, SAgraphics
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: i cant install autocad 2009 in windows vista 64
Hi, at the moment autocad 2009 has no support on vista 64 bit. They deliberatly disabled the software to install on this system. Here is a link that provides an workaround the problem http://discussion.autodesk.com/forums/thread.jspa?threadID=562426
Regards, Paul
SOURCE: I NEED TO CHANGE FROM 64 BIT VISTA OS TO 32 BIT " XP OR VISTA OS
Ummmm. Its quite expensive to do that but i suppose if you need to ten its a viable option. You could buy a cheap 32 bit machine instead or try downgrading vista.http://www.microsoft.com/windowsvista/1033/ordermedia/default.mspx This may help you if you retail bought the machine.
SOURCE: no sound output through hdmi windows vista 64 bit
You will need to change your default audio output from analog to digital.
Double-click on on the little volume icon in the system tray (lower-right corner), to select which source you want to output your audio.
SOURCE: Problem with the HP G60-235DX
Have you checked the settings of your synaptics? Usually there's an Icon on the taskbar for synaptics you can right click it and check if "disable touchpad if usb pointing device is present" is checked, if so uncheck it then your touch pad should work again.
Here's a link for a step by step instruction though this is for windows xp but steps are the same. Hope this works for you:
http://blueboxagency.com/helpdesk/?page_id=16
