Question about T-Mobile Dash Smartphone
I HAVE A PROBLEM WITH MY DASH
MY DASH WAS WORKING FINE AT FIRST BUT A MONTH AFTER I GOT IT. IT STARTED ACTING UP WILL NOT POWER ON ALL THE WAY. WHEN I TRY TO WORK IT THE ONLY THING THAT HAPPENS IS THE RED LIGHT APERS WHERE THE GREEN LIGHT SUPPOSE TO BE ON POWER ON POWER OFF THE ONLY THE YOU SEE IS THE TMOBLIE START UP PAGE AND IT SAYS WINDOWS MOBILE AND THE TMOBILE END PAGE AND SHUT RIGHT BACK ON. Please help me get my phone in order thanks.
Shavon
  • 72 Answers
Try the usual, take the battery off and reset the phone using the button underneath where the battery was, put the battery back in place and then try to start your phone. If your still having the same problem then return to your service provider and have your phone either reprogrammed or possibly sent in for repair. hope this helps! :)
Posted on Nov 19, 2008
My lcd works fine untill i flip upside down
There is may be a problem with your power cable. You need to fix it properly.
Jul 23, 2013 | Dell ST2310 23 inch LCD Monitor
1995 sl1
replace ignition coil
Jun 20, 2013 | Saturn Cars & Trucks
99 Nissan pathfinder le. I was driving and lost all power (lights, dash lights, hazards, everything). I had the alternator tested at auto zone and it was putting out +14. I replaced the battery and it...
You are throwing away money by replacing g parts that are likely just fine. Check for an ecu relay. My wife's 06 has an IPDM/ecu relay issue that will cause the vehicle to just die. It gets corrosion inside the contacts and cuts power to the computer. I had already purchased a spare for a couple dollars. Wife was close to home and car died, started back and was acting up. Swapped the relay in about 2 minutes and no issues since (several months now). Sometimes a small part can cause big problems. You can't just throw money at everything hoping to fix it. You need to do some research and troubleshooting.
Apr 29, 2017 | Cars & Trucks
Electrical on 2001 Alero GLS
What you listed is controlled or powered by the key switch. If those fuses do not have power, I would check the key switch first.
Sep 04, 2012 | Cars & Trucks
Blinker, cruise issues...electrical?
The problem is caused by the emergency flasher unit. This is a common problem and you can find a few youtube demos on replacing it. I did it in about 30 mins. I don't remember the cost but it was stocked at my local chevy dealership.
good luck.
Feb 10, 2012 | 2002 Chevrolet Impala
My 1992 chev lumina apv van stalls everytime i put on the brakes at every red light it restarts after no codes are coming up what could it be?:
check to make sure the power brake booster is not leaking, do this by starting the van and just let it idle in park and push the brake pedal if the engine stalls or surges or you hear a sucking noise under the dash then replace the power brake booster if there is none of these systems then replace the idle control motor. GOOD LUCK
Mar 08, 2011 | 1992 Chevrolet Lumina APV
2006 jeep grand cherokee won't start every now and then dearler can't find anything everything comes on lights dash radio works but will not start one time got it started in neutral
gear selection cable might be out of adjustment. neutral safety switch acting up. possibly a defective ignition control module. they get flaky like that. work fine then all of a sudden they wont start 1nce or twice, then they work fine for months then dont work for a day or two.
Jul 31, 2010 | 2006 Jeep Grand Cherokee
My 2004 suzuki aerio would not start last year. I put a starter in it and it ran fine for 6 months.Then it would not start again. I put new battery cables on and it atarted fine for 3 months. Now it won't...
your comp is not reaspondig/acting the way it shoud so until everything is new it aint gunna start because it only starts wen u put something new comeone just think about it
Feb 18, 2010 | 2003 Suzuki Aerio
All dash lights on
Many times, When electrics act up. it has to do with a ground problem. Fuses must be good you have power. Auto electrics like to have a single wire running to the device and then depend on a ground near by to grounded steel instead of a return wire. Loose grounds have no return and the device acts crazy and will be erratic, and not act properly. No where for the electricity to go. Eliminate the possibility of bad or missing grounds first, then get out an electric volt ohm meter, Start checking voltage, and eliminating things that have proper and constant voltage. Then look for bad devices. Just trying to save you some money. Electrical Trouble shooting can be time consuming and expensive. You can do it. lbreen
Apr 22, 2009 | 1986 Pontiac Grand Am
Electrical problems
I have, when I first bought my 02 Liberty. It ended up being a faulty ECU. ECU is the computer brain that controls the whole car. I had it replace and it never happened again.
Sep 09, 2008 | 2002 Jeep Liberty
T-Mobile Dash Smartphone Logo
43 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
