Question about Maytag MEW6627D Electric Double Oven
Steam from oven scaled cabinet above oven
When I cooked my Thanksgiving turkey, I used convect bake 325, so much steam came out of the oven while the turkey was cooking that it scaleded the cabinet (totally removed the finish) on the cabinet door above the oven. All the steam came out of a small vent on the right top side of the oven. I have cooked turkeys before (I have had this oven for 2 years 2 months) and this has never happened before. Luckily, I am putting new cabinets in as we speak but I am terrified of using the oven again. Help! I have asked the kitchen salesman and the contractors and no one has ever seen this happen before. What could it be? I don't want to get a new oven but I can not afford to have this happen with the new cabinets. Any advice or help would be greatly appreciated.
4 Suggested Answers
muffteck
  • 202 Answers
SOURCE: Cleaning Inside the Glass Window
u will have 2 take the door apart to remove glass
Posted on Mar 27, 2010
  • 51 Answers
SOURCE: How far does wall oven
well they can be pretty close because there alot of insulaion in the side and back of the oven. about a 1/2'' is okay really i've been in houses where it's touching the cabinets
Posted on Mar 22, 2011
richroth
  • 9472 Answers
SOURCE: Stuck oven light bulb
I use 2 sided tape to get a grip on the bulb. If it is really stuck and you end up breaking it, don't worry as it will be easier to remove the rest of the bulb with a pair of needle nose pliers.
Posted on Nov 24, 2011
How do I bake a store bought frozen pie in my proline convection oven ?
2 Easy Ways to Cook a Frozen Pie - wikiHow
https://www.wikihow.com/Cook-a-Frozen-Pie
  1. Cached
Rating: 64% - ‎28 votes Baking a frozen pie can be simple-open the box, toss the pie in the oven, and ... I baked a store-bought frozen pie in my new oven in the regular bake mode. Missing: proline
Baking Directions - Willamette Valley Pie Company
https://www.wvpie.com/products/baking-directions/
  1. Cached
  2. Similar
DO NOT DEFROST, keep this pie frozen until you're ready to bake it. ... If the crust becomes darker than you think it should be, cover it with foil for the last ... Convection oven: Bake for 80 to 85 minutes at 330 degrees F. Ovens may vary. ... Our Product Line · Buy in Your Area · Fundraisers · Baking Directions · Pie Ingredients ... Missing: proline
How to get pie crust to brown on the bottom - Flourish - King Arthur Flour
https://blog.kingarthurflour.com/2017/.../how-to-get-pie-crust-to-brown-on-the-botto...
  1. Cached
Nov 13, 2017 - KitchenAid Pro Line Mixer ... Getting a brown, flaky/crispy bottom crust on your pie is all about ... Placing them on the oven's middle rack to bake resulted in pie with ... And you can keep using it - so long as you place it on your oven's .... For a two crust apple pie convection bake would work, but I would ...
43 best Eat Convection Oven Recipes images on Pinterest ' Cooking ...
https://www.pinterest.com/candijjj/eat-convection-oven-recipes/
  1. Similar
See more ideas about Cooking recipes, Toaster ovens and Convection oven recipes. ... Bring the oil to a boil for a quick and easy dessert recipe for chocolate ...... Toaster Oven Recipes - Prepare Chicken Pot Pie in a Toaster Oven! .... Tip: If you can& find microwavable ravioli, use one bag to 16 ounces) frozen ravioli.
32 best Toaster Oven Treats images on Pinterest ' Toaster oven ...
https://www.pinterest.com/blackanddecker/toaster-oven-treats/
  1. Similar
See more ideas about Toaster oven recipes, Toaster ovens and Convection oven recipes ... Homemade Toaster Strudels - these are SO much better than the store bought kind... ...... Toaster Oven Mini-Pies are easy to make and absolutely yummy! ..... Oven toasted Ravioli using frozen ravioli, sounds like a yummy appetizer ...
May 24, 2018 | Ovens
HOW TO KEEP IT JUICY AND TENDER IN OVEN?
Brenda, they now sell a type of oven bag that will help you out.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Bags
How to make moist Thanksgiving Turkey using reynolds oven bags
Mar 23, 2016 | Ovens
What is the best setting for my viking on a 14 pound turkey, bake or do i use the convection broil?
Use the regular bake setting.... run the oven at 350.... the 14 lb. bird will take about 4-5 hours.....convection moves air and can tend to dry out the bird...
heatman101
Nov 25, 2010 | Viking 30" Professional Select Built-in...
I think the oven is not getting hot enough,i have baked three
Buy an oven thermometer to check if the temperature you set the oven at is accurate. You may have a faulty thermostat, but if the temp is only off by a little, you can calibrate the temp setting on the oven by as much as + or - 25 degrees. If you have an LCD screen, then most likely you can adjust it right on there. If not, then the backside of the oven knob can be adjusted + or -. by moving a set screw and turning as needed. Your owner's manual will have a more detailed explanation on this procedure. Douglas
Jun 13, 2010 | KitchenAid 30 in. Architect II Series 4.3...
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Viking Ovens
    Convection oven quit working half way through cooking thanksgiving stuffing
    Call us right away with your brand and model number and we'll get the correct part out to you right away in time for Thanksgiving turkey!! We look forward to
    working with you.
    Oct 18, 2009 | Ovens
    Baking with digital oven
    First let me address the temp ... Buy a meat thermometer and test it against the temp set in the oven.  Though that isn't the most accurate, it should prove whether or not it is way way off.
    Second.. convection baking takes considerably less time....
    Third... elevation plays a key factor on baking but not so much on cooking meat.  Baking above 2500ft elevation takes 20% longer and above.
    Mar 08, 2008 | GE Profile JTP18 Electric Single Oven
    Amana Convection oven not controlling temp
    I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
    Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
    Maytag MEW6627D Electric Double Oven Logo
    Top Maytag Ovens Experts
    Carmen Mikulic
    Marvin
    Marvin
    Sal De
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
