Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Engine won't start
Put oil in the fuel tank
  • 1 more comment
  • vsalito Nov 19, 2008
    I tried that already but still won't run. I think the carburetor is clogged with the oil.
    Your suggestion would be very helpful if I had a clue as to how to rebuild the carb. However, I'm not mechanically inclined and therefore clueless.
  • Marvin
    Marvin May 11, 2010
    RINSE THE TANK OUT WITH GAS, THEN ADD FRESH GAS, START THE CHAIN SAW WITH STARTING FLUID TO **** THE REST OF THE OIL THROUGH THE ENGINE, IF IT IS A 2 CYCLE MIX THE FUEL ACCORDING TO MANUFACTURER SPECS.
    Top Expert:
  • Husqvarna Master
  • 81,423 Answers
The carb is very simple, rebuilding it is a 1 hour job, Have you tried theis mehtod several times?
Posted on Nov 19, 2008
  • Marvin
    Marvin Nov 19, 2008
    I am sorry about the lack of skill, but there is a 1st time for everything, give it a try, use a digital camera to record how everything goes together
Accidentally put oil in gas tank it starts up but doesn't accelerate now
pull the hose of the outlet side of the fuel pump and pump fuel out of the tank
refill the tank with fresh fuel
replace the filter
not much more can be done but to run the engine and flush the oil contamination through
will not harm the engine but is inconvenient
Aug 06, 2016 | Cars & Trucks
With apprila Rs 125cc 2 strokes bike. I fill up with 98 octane unleaded and I poured 2 strokes oil Into petrol tank. is it possible can damage the engine?. at the moment I couldnt start the engine.
well you cant damage it by doing that but if you put too much n and didnt shake it well it will settle at the bottom of the fuel tank and fill the carburettor up with oil as oil is heavier than petrol.why are you not using the oil tank and oil pump fitted to the bike ?best thing to do is put a new spark plug in it turn the fuel tap off roci the bike bacwards and firwards to mix the oil and fuel in the tank,and drain the carburettor by undoing the 14mm nut in the centre of the bottom of the carb,then turn the fuel back on and try and start it up.
Dec 10, 2015 | Motorcycles
97 mercury mountaineer. won't start
hi,
watch your oil pressure when cranking, you have to have some oil pressure to get the fuel system to start. you may have to find the hot wire at the relay and energize it to see if it is indeed the fuel pump going out. if its been sitting and its a 97 the fuel pump just might have went, you can also try hitting the gas tank from the outside in the middle to see if that works too. have a water hose or fire extinguisher around when your working on fuel system and leave one of your battery cable a little loose..
jm
Jul 04, 2017 | 1997 Mercury Mountaineer
When you start engine you have to give it gas or it won't start
replace your fuel & air filters, add some fuel injector cleaner to gas tank, todays fuel w/ ethanol is hurting your engine, change your oil also.
Mar 01, 2013 | 2003 Chevrolet Impala
What problems can take place if i put watered down gas in my oldsmobile araura
Should not have caused significant damage. Change the oil and check again after a few days.
Aug 10, 2017 | Oldsmobile Aurora Cars & Trucks
Honda GX160 firepump runs good than dies starts first pull after and repeats
Check that the fuel tank is venting properly, sounds as though the tank is not venting therefore creating a vacuum that the carburetor cannot over come. Try running the engine with the fuel cap loose to see if that alows the engine to continue to run.
Dec 16, 2012 | 5.5hp 6:1 Gear Ratio GX160 Engine
I changed the oil in my 98 concorde and now it wont start. The oil light is on but not the check engine light.\
do you here the fuel pump working when you turn the key?If not could be a fuse that runs the fuel pump.
Aug 05, 2012 | 1998 Chrysler Concorde
Accidentally put mixed gas and tried to start. Blew white smoke after starting but wouldn't run. Drained tank and put premium back in now won't even start.
There will still be some fuel mix in your fuel lines and filter. Also it probably fouled your spark plug. Try changing the spark plug first, and probably buy an extra one or two to keep in case. Also either replace the fuel filter or clean it out good, oil will stick to the elements in the filter. It won't hurt anything to run a mix in a gasoline engine, just lubed things up a little extra. Let me know if you need anything else, Daniel.
Oct 13, 2011 | Polaris ATV
I have a Toro 4 cycle gas trimmer that won't stay running. Starts, then sputters, then dies. I've changed the oil, drained fuel & put in new fuel.
check to make sure the air filter and the fuel screen are clean, the screen is the little white plastic piece on the end of the hose in the tank. if it is still sputtering try cleaning the bell out on the carb. it is the little metal cylinder on the bottom of the carb where it holds the fuel until it evaporates into the engine if it gets clogged the engine will not run properly.
Jun 30, 2011 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
47 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
