Question about Kenmore 46462 Front Load Washer
The drian pump is plugged with lint ,etc. how do I remove and cle
A stffed pillow split open and clogged the washer . I 2nd rinsed drained most of the water out and got the door to open and cleaned out the tub
What is the best way to take apart clean and put back together also I need a schematic of the washer.
    Genius:
  • 1,028 Answers
Remove bottom cover turn pump clean out port counterclockwise clean pump and retry..tech sheet is to right of pump
Posted on Nov 19, 2008
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Won,t drian the water.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 21, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water does not drain from machine
Check these:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
Sep 07, 2009 | Westinghouse WWS833ES Super Capacity Top...
The washer was one last rinse and stop did't drain?
Generally a bad drain pump or a clogged drain pump or drain hose. Have a look and let me know what you find.
Benjamin
Aug 09, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Cabrio washer wont drain
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Best of luck :)
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Halp
Hello it could be your lint filter or a hose is blocked by an object. May be even in the pump. Had a similar problem with our Maytag. Cheers.
Mar 08, 2008 | Washing Machines
Wont drain
Sounds like you have a bad lid switch.I would need additional info on the unit,make,model etc.
Nov 21, 2007 | Indesit W 123 Front Load Washer
Will not turn on
If led'slight up when POWER button pushed but nothing happens when START button pushed ITis likelt to be lid reed switch open circuit or pump is open circuit .If nothing lights up when turned on at wall socket suspect controller dead or pump open circuit.Pump sounds like it has caused problem joker 120 need to check loop resistance of pump 35ohms for Aus/NZ
Nov 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel "clog Problem"
the water comes through 2 vavle 1 for washing and the other for rinsing more than likely that the rinse valve is down it will need replacing thats the more common fault for washers not rinsing
Aug 11, 2007 | Fisher and Paykel GWL11 Top Load Washer
Code LD
Here we go the problem probably lies in the holding tank tub. So far found one baby sock, clumps of lint, latest underwire from daughters bra. Easy to work on machine. Will need a 2nd person for 1st part of repair. Have a small bucket ready,(I used a empty kitty litter container) 1)Disconnect electric cord, 2)Disconnect water hose's to machine. pull out drain.3)(Will need a 5/16th socket.) Pull out washer remove back panel.(2 screws) 4) Tilt back washer (towards control panel) 5) Remove bottom access panel (3 screws). 6) With a pair of plyers pull back metal clip on hose leading to pump. (this is where all water left in washer will come out.) 7) Remove clip on return hose from pump. 8) Pump is held on by 2 clips, push them back to remove pump. Once a water is drained you should be able to see any objects in the tub area, you can also now place the washer on it's side.WATER MAY STILL COME OUT HAVE A TOWEL OR 2 READY. Check pump for damage. Remove any/all debris (Used a set of hemostats.)(Rubber balls are suppost to be in there.DON'T DAMAGE THEM.) Once everything looks to be removed. Reverse steps reattach hoses, pump, etc. before replacing access panels Use the Express Wash Option to see if all works well. If it does, reattach access panels, and start washing!!
Sep 06, 2006 | Kenmore 22062 Top Load Washer
Kenmore 46462 Front Load Washer Logo
83 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
