Question about Ingersoll Rand Hvlp Automotive Spray Gun
IR 210g - using thicker paint
I am having a hard time getting a good coat on. I am using a water base latex paint. When i first tried sparying right out of the can, it would hardly spray. As I thinned the paint to the max recommended by paint manufacture, it did a little better but still very thin.
I am spraying at 45psi, air valve open 100% and needle all the way out.
am i doing something wrong?
  • 700 Answers
We do have here cardinal problem... this gun is totally and utterly unsuitable for latex paints! it's nozzle size is 1.4mm, for latex you need at least 1.8mm and preferably 2.4mm, if undiluted even more... any trickery with air flow valve, paint flow (needle) valve or spray pattern will not work, latex particles are long, stringy and clingy - you do need bigger nozzle and that is all...
by the way - it is lovely gun, nice to hold and work with, but it is usable for fine particle paints only, regardless water or solvent based, it is fine gun, but haevy paints based on latex or bitumen will physically just not go through it correctly...
hope this will help you at least a bit, please post your comment how it work for you.
Posted on Oct 20, 2013
  • 3 Answers
Thinning the paint is always best,but some gun manufacturers dont put on an air cap recommended for latex paint try using an air cap with biggers holes this will allow the paint to flow through better.It could be that the air cap you use now has to small of holes for the paint to flow through.
Posted on Dec 18, 2008
  • 23 Answers
I dont have so much as a solution as a couple of things you can try to figure out whats going wrong.
make sure your compressor can handle 10.5 CFM @ 50psi
hook up the gun and dry spray it to check for blockages in the air supply
if the air comes through strong and constant, fill the paint hopper with water and spray until empty
if the water comes through constant, add half of the hopper with paint thinned with penetrol or floetrol
if the paint is coming out weak or spotty, make sure the vent cap is open on the paint hopper
if the cap on the hopper doesnt have a vent, try spraying with the cap off or cracked a bit.
if that doesnt work take off the hopper and check the filter for blockages.
i suggest straining all your paint before pouring it into the hopper
Posted on Nov 22, 2008
Painting- do I paint oil based paint over water based or water based over oil?
rule of thumb is that, given proper surface preparation, for exterior use you can apply quality latex paints over oil-based, but not the reverse. However, if you have many layers of oil based paint, stick to using oil on oil.
Sep 07, 2017 | Air Tools & Compressors
I painted over a piece of furniture with water based paint which is chipping. can I paint over this with oil based paint?
Yeah, you can, but I wouldn't. Generally speaking, you can cover latex with oil, but the fact the latex is chipping indicates a bonding problem with the latex. Chances are if you just cover it up, it will continue to peel underneath and create bubbles in the oil base.
Jul 27, 2017 | Air Tools & Compressors
How to prep to paint a steel exterior door
Use a sponge sander to send the door and top coated with DTM metal paint it is a water-based product
Aug 10, 2014 | Home
I have an old white refrigerator that works fine, just looks awful. What can I do to the face to make it look nice. I have wooden oak kitchen cabinets and a tile floor.
Paint it with white enamel.
Enamel Paint finishes in high gloss if you want that sort of finish.
Always paint in a dust free invironment with plenty of ventiallation.
With the expensive cost of many home appliances, sometimes replacing an old refrigerator is out of the question, especially if it still works well.
This can be a problem if you've recently painted your kitchen or if you're just sick of looking at an old, outdated fridge.
Instead of learning to live with your boring or unattractive refrigerator, you can give it a bright new look with a few coats of paint.
Mix a few tablespoons of vinegar into a bucket of warm soapy water.
Use this mixture to clean the refrigerator.
Scrub away any grease, dirt or other grime with your soapy water and a stiff bristled scrub brush. Wipe the refrigerator dry with a towel when it is clean.
Use painter's tape to cover parts of the refrigerator you do not want to paint such as the handle or the grate at the bottom of the refrigerator.
Apply a coat of appliance paint to your refrigerator with a paint roller to prime the surface.
You can also purchase appliance paint in a spray can and use it to spray paint your refrigerator.
Sand the paint with an extra fine grit sanding sponge when it is completely dry.
Try to make the surface as smooth as possible and then wipe away any dust created with a clean towel.
Paint the refrigerator with an enamel paint tinted to the desired color and a paint roller.
You can use oil-based or latex-based enamel depending on your preferences.
Oil paints usually have a stronger odor than latex paints but they may last longer.
Apply a second coat of paint when the first coat is completely dry.
Sand the final coat of paint when it is dry with a wet extra fine sanding sponge.
Spray the refrigerator with water while you work to keep it damp and keep sanding until the paint is smooth and shiny.
Remove all of the painter's tape from your painted refrigerator.
Sep 08, 2013 | GE Refrigerators
Won't spray
There are a lot of variables while airbrushing. If you are having trouble with a new airbrush(or one that isn't hugely gunked up) you likely need to do 1 or both of the following to get it to spray the paint:
1) Thin your paint, use the correct medium based on the paint type. Water can be used to thin water-based paints but too much will result in a bad coat and finish. You are looking for a milk-slightly thicker than milker consistency.
2) Crank up the air through the airbrush. Assuming you have a regulator you may need to turn the pressure up to get thicker paints to spray. If you are using a siphon feed you may need a couple extra PSI to recoup for what you are losing from the syphon. Make sure to check the max pressure your airbrush can handle before cranking it too high(most can handle at least 30 PSI).
Hope this helps.
Jan 23, 2013 | Airbrush-Depot Master Airbrush Model G23...
I have the hds780rs0605 I need to know if I can use latex paint for my walls and how to with out it clogging up
Let me start by saying these types of paint sprayers are not usually recommended for painting large things like room walls because you're going to spend a lot of time refilling the paint cup. The cup only holds 20 ounces of paint and that won't go very far on your walls. If all your paint isn't mixed and properly thinned at the same time your walls could end up with a checker board look. You would usually be way further ahead to rent an airless paint sprayer.
If you have to use it; first run your paint through a paint strainer, avaliable at any paint or box store (The Home Deopt, Lowes, etc). Even new paint has impurities that will clog paint guns. It's highly recommended you mix in a paint conditioner like Flotrol but not absolutely necessary. Next, you're going to have to experiment with the consistency of the paint to get a good even flow out of the gun. The thinner you have to make the paint to get a good flow, the lighter and more coats you're going to have to apply. It's also recommended to run a paint soaked roller over the wall right after you spray it to even out the paint and remove any overlap marks.
Aug 05, 2012 | Air Tools & Compressors
On a Campbell Hausfeld DH5030 spray gun, there is a screw valve at the base of the unit with arrows labeled S and P for turning clockwise and counterclockwise, respectively. What is this for?
The "P" stands for pressure feed. turning it completly to this side forces air into the cup pushing the paint out.
The "S" is for siphon feed where the air through the tip sucks paint from the cup.
If your using thin materials like lacquers or polyurethane or solvent based enamels the siphon feed is used.
If your using thicker materials like water based latex or heavy stains then go with the pressure setting.
You can always go in between for some pressure with the siphon action....depends on coatings used.
Jun 22, 2011 | Campbell Hausfeld DH5300 General Purpose...
I am an experienced spray painter, but I have been out of the game for a few years and things have changed in that time. I am familier with most types of paint, including synthetic, cellulose, 2 pack and...
water base paints are out there but as far i know i think you should error on the safe side and use a resporator with most all paints........ as far as i know they havent fully improved waterbase paints to the point that they hold up on metal correct me if i am wrong when the car companys use them for all cars then i will! ( base coat clear coat is the best so long as you follow the mixtures as directed on the cans ( call some paint suppliers , savage dupont ect they can guide you on most types of paints)
Feb 24, 2011 | Air Tools & Compressors
What is the correct concistancy the paint needs to be mixed at for the dynatec psg 45 electric spray gun
It depends on 3 things.
What you are painting.
Whether you are applying latex, oil-base, or primer.
What size TIP you are using.
We use spray equipment and use size 17 and 19 for latex, and 11 for oil.
Double-check the size that came with your gun and look at tips at Home Depot.
Old tips wallow out and the spray pattern is irregular/uneven and the gun blows out too much paint and our material costs go up.
The manual says "dilute correspondingly"
http://www.airless.com.au/Airless%20Sprayer.pdf
Let's say you are spraying oil-base stain: I would NOT dillute this material.
Oil-base primer: 1 thinner to 4 paint
Latex primer: use a roller and brush so you have a good undercoat for the paint.
Oil-base paint: I would add 1/8 thinner with 1 paint, and be careful of runs
Latex stain: try 1 water to 4 stain
Cheap interior flat latex: 1 water to 4 paint
Latex semi-gloss interior: 1-1/8 to 4 paint and apply very thin coats and let dry between coats.
Cheap exterior flat latex: 1+ to 4 paint, and add more or less water as needed
Good exterior latex paint: use a roller and brush because the purpose of latex exterior pain is to apply heavy protective coat over outdoor materials ... dilluted exterior latex will not give sun and mildew protection.
We use heavy spray equipment and apply exterior latex straight form the can. It's the only way to give lasting job, unless you're doing a temporary playhouse.
The key to successful spraying is to strain your paint to get out the lump and clogs - BEFORE putting paint into the gun.
We always strain the paint unless it's a freshly opened can.
If can was opened yesterday, we strain it.
That because paint gets a dry film that will clog the sprayer.
First you need to mix your material, so you need a couple buckets.
Pour the paint and thinning material in 1 bucket, and then to mix, pour back and forth between two or three buckets. This action will mix the paint thoroughly and save you an hour of rotating a paint stir stick.
Next, you need to strain the paint.
Wash out a 5-gallon bucket.
Buy 5 gallon strainer that fits into bucket.
Pour material into bucket with strainer, lift strainer up and then grab end of strainer and squeeze out all the paint.
Immediately put lid over paint so no drying film will form.
Wash out strainer.
You're ready to put paint in spray gun.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on paint project.
Jan 06, 2011 | Garden
Ingersoll Rand Hvlp Automotive Spray Gun Logo
615 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
