Question about Swiss AIR-O-SWISS Ultrasonic Humidifier - Model AOS 7135 Humidifier
Default setting too high
I cleaned my humidifier with the EZ Cal stuff as I have on many occasions with no problem. Now, the default humidity level is at 80%, i.e., that's what the humidifier is reading as to the room's humidity level. As a Colorado resident, I know that ain't right. The result is that the humidifier does not register the need to humidify, as it were.
  • Anonymous Dec 02, 2008
    Used the ezclean and now I am at 71% while my digital hygrometere reads 30% to 34%.
  • albyD Dec 26, 2008
    I have the same problem. I just cleaned the humidifier with EZ Cal, and now it's stuck on 80%.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 28, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
What is the gallons per 24hour output capacity of this unit?
There are several variables that will determine the gallons used per 24 hour period.
  • At what humidity level do you have it set for? The higher the level, the faster consumption.
  • How much air movement is there in the are in the house/area of the humidifier?
  • How air tight is your home?.
  • How may people occupy the home?
  • Whats the temperature setting for your primary heat source?
Let's assume that everything is perfect. Your humidifier holds approximately 6 gallons of water, when completely full. The ideal humidity level depending on the outside air temperature is 40 to 50%. Once the humidity level you have it set for is reached, the humidifier shuts off. When the humidity level drops significantly, it turns back on. So, as you can see, it's difficult to come up with an exact figure. But based on if everything was perfect, about 1.5 to 2 quarts per hour or almost 6 gallons in 24 hours.
For more details on this humidifier call 1-800-546-5637.
Hope this helps you.
Feb 09, 2011 | Holmes Products Cool Mist HM3500...
Motor runs, but does not collect any water in yank
Make sure any air filters are clean. Check to be sure the evaporator and condenser coils are very clean. Also could the humidity level in your home just be very low right now and just no moisture to remove? If all of this fails it could be a compressor problem or a refrigerant level issue. If this is the case determine if it is worth the expense to repair.
Good luck
Mar 28, 2009 | Whirlpool AD25BBR 25 Pint Per Day...
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
Air-o-swiss 7142 humidifier
I just cleaned mine for the first time, and the instructions are very unclear in the pamphlet on how to do it.
What you need:
One package of EZ Cal cleaner/descaler for humidifiers ( I got mine at bed bath and beyond)
32 oz of hot water
How to clean your unit:
Mix the hot water with the EZ Cal cleaner packet in a separate container.
Remove the tank from the base.
Remove the cleaning brush and the silver stick that is in the base of the unit.
Pour the solution in the base of the unit.
Let the solution sit in the base of the unit for 1/2 hour.
Then take the cleaning brush, and go over the surfaces in the base.
Pour out the solution, and rinse with hot water.
Put the brush and silver stick back into the base.
Put tank back onto the base.
Reset the unit by pushing and holding the power button for a few seconds.
This will stop the cleaning indicator from blinking.
Let the water fill up the filter for a couple minutes, turn on, and your ready to go again.
I hope this was helpful.
Nov 03, 2008 | Air-O-Swiss U7142 Humidifier
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
Place unit on level surface away from direct sunlight.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Humidifier occasionally runs in spurts (on for 2 secs and then turns off)
It's just trying to keep the humidity level you set it at. By dropping the temperature in your home or changing the humidity level you want you can avoid this.
Good Luck.
Feb 12, 2008 | Lasko 1128 Humidifier
My guess is that you are trying to bring the humidity up too high. There is a chart in the manual that suggests where to set the humidity at based on outdoor temps.
I try to keep the level at 30-35% in the winter.
Hope this helps.
Dec 02, 2007 | Kenmore 14410 Humidifier
Swiss AIR-O-SWISS Ultrasonic Humidifier - Model AOS 7135 Humidifier Logo
57 people viewed this question
Top Swiss Humidifiers Experts
Paul Carew
Are you a Swiss Humidifier Expert? Answer questions, earn points and help others
