Question about Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player
Radio Station Presets wont hold
When I set the presets for the radio stations they will only stay until I turn the car off. When it's turned back on all the presets are gone.
  • tammywithawh
    tammywithawh Jan 31, 2013
    Okay I have a Kenwood kdc252-u, and was having the problem of it not saving radio stations or audio control settings.. So I pulled the stereo out to switch the wires as you said, which I thought would work... But now nothing is working at all.. hmm even when I switched the wires back,,,
    Problem Solver:
  • 14 Answers
Hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Posted on Nov 19, 2008
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
How do you assign preselect numbers to radio stations
You can assign radio station presets on your stock VW radio by tuning to the radio station you would like to preset, and then holding down one of the preset number buttons until the radio beeps. You will now be able to access the station by pressing the preset button.
Oct 15, 2013 | Vehicle Parts & Accessories
How do I set the presets on my radio. I don't have a manual and can't figure it out
start the car turn the radio on scroll to the station you want then push and hold the preset button 1 thru 9 untill it beeps then go to the next station you want to set and do the same.
May 15, 2011 | 1999 Jaguar XK8
Have lost four preset channels on my Technika DAB 109CR digital clock radio and lost manual so have nothing to consult to get back these stations. Everything live but showing only one station constantly
Finally sussed out how to (re)set presets, overall you need a little patience:
Probably best to press Autotune before we set off and let it do its thing.
Press 'presets' and find a free channel or the one you want to change, leave it until you can hear the station its on play.
Now, press 'jog/select' and WAIT until it says <SELECT> (but don't wait too long when it says this or you'll have to start again)
Use dial to find station you want AND LEAVE to tune in.
Press AND hold presets down until number flashes.
Press jog/select once briefly (normally).
Press presets once briefly...it should now say "Saved"
Leave to save for a few seconds.
Voila!
You can now change station either by pressing Presets and moving dial...waiting for the station to load OR press jog/select to manually tune to the station of your choice using the dial.
Feb 20, 2011 | Audio Players & Recorders
Seting radio presets
tune the radio to the station you want stored then push and hold the memory button before pushing and holding the preset button until station gos off and back on.
Jul 18, 2009 | 1984 Honda GL 1200 Aspencade Gold Wing
Car stereo preset radio stations.
Manuallly set to the station you want,then pick a preset button & hold down until you hear a beep or 4 about 5 secs
May 16, 2009 | 2000 Saturn SL
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Radio presets?
select radio station then select which number you want to preset station to and press and hold until you hear the unit beep,also preset station will flash once aswell as the beep,station should be preset into your headunit,goodluck.
Nov 29, 2008 | Pioneer Car Audio & Video
Radio presets on my toyota camry 1998 will not hold any more.
be sure when setting presets you hold the button down for at least 3 seconds to set the channel, if you are doing this correctly, you may have a blown back up fuse under the hood. there are 2 fuses for the radio one is marked radio and is inside the fuse pannel on the inside of the car the other is for memory back up and located in fuse box under hood may be marked B/U just check them all to be sure!
Nov 19, 2008 | Car Audio & Video
Set Radio Station Presets
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
Oct 09, 2008 | 2001 BMW Z3
Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player Logo
435 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
