Konica 2125 copier has F36 printer (power was shut off to building). How do I reset it?
  • markeeees May 11, 2010
    this is a fuser error code it may have blown the fuse we can try to reset . Is there any other #'s fallowing the 36?
Nitrotrike
  • 589 Answers
SOURCE: Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Posted on Jan 07, 2008
SOURCE: error code f35-6 on konica 7145 copier
Replace Thermo- fuse (open ) fuser not getting to 160, and clean thermister, toner builds up between roller and thermister causing overheating of fuse to blow .
Posted on Apr 25, 2008
  • 126 Answers
SOURCE: Error Message on copier.
Probably a thermistor problem, dirty or out of position or failed. Could be thermostat too.You will want to check that fuser out first before you reset any codes. Checking for paper, sensors, etc...
If all is clear in the fuser then:
With the power off, hold the 2 and 5 button on the panel and turn the power on. In the display you will see, there are 1-12 choices, choose 1, Software SW. You will see a display of numbers (01-0:1 03). Change the first number to 03, change the second number to 01, change the third number to 00. Press RETURN on the display. Power the unit off, then on. Codes should be reset.
If after resetting the code and powering up machine -- if code comes back then replace the above mentioned.
Posted on Jan 24, 2009
  • 51 Answers
0000
Posted on Aug 31, 2009
firecontrol7
  • 6400 Answers
SOURCE: Konica 7065 with error code
Sir,
Fuser Code (Hot Unit has over heated) To reset you will need to go to 25 Mode to enter his mode you must turn off the machine then holding down the 2 and 5 button turn on the machine, hold them 25 down for at least 30 second once in 25 mode select SW (soft Switch) select "3" then "3" it should be a "1" change to a "0" then exit and turn off the machine and turn "ON".
Posted on Feb 27, 2010
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Konica 7020 trouble code 36-1
dear need help to resite l detect value auto adjustment developer konica 7020
Feb 26, 2013 | Office Equipment & Supplies
My konica 4355 is showing f36-1 error what could be the problem
Fuser Section overheaded (HOT SECTION) can be reset in 25 Mode. If it comes back Fuser needs replacement part(s)
Feb 24, 2010 | Konica Minolta Office Equipment & Supplies
Error konica 2125
Hello sir; On the control panel upper left corner there have a dial turn dial clockwise it will be bright.
Aug 14, 2009 | Konica Minolta Office Equipment & Supplies
I connot remember the pasword to open reset code. it was an accident to ON the switching 2-6. THE PROBLEM NOW IS I CONNOT RESET THE CODE F36-1
I can give you a generic solution.... You did not give a model number. Some are different.... Is it a Konica or is a Minolta based copier???? Try this press the user choise botton then when then the display changes - press the meter count - then press Stop - 0 - 0- Stop. The display will change to Service mode.. That is if it is for your generic Konica Minolta copier.. Good Luck
May 02, 2009 | Konica Minolta Office Equipment & Supplies
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Error code f35-6 on konica 7145 copier
Apr 25, 2008 | Office Equipment & Supplies
Konica photocopier
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
170 people viewed this question
jasbo
jasbo
