Question about Lexmark X4270 All-In-One InkJet Printer
Is there a way to mark faxes?
My grandfather is wanting the faxes he receives to be marked whenever they are put through. Is there a way to change settings to allow this?
    Sergeant:
  • 390 Answers
Hi, can you clarify what you mean by marked??? Do you mean a transaction report or marked as read or something like that? Please post back.
Posted on Nov 21, 2008
How do you find out what chain a movement uses on a Kieninger
Hi, Mark for more information about your question and a valuable "FREE" download that you will need please click on the link below. Good luck and have a nice day.
INSTRUCTIONS FOR KIENINGER GRANDFATHER CLOCKS Grandfather Clocks 123
Nov 27, 2016 | Kieninger Home
When I press print, it shows up as my default print is my fax. How do I change the default printer to be just the printer instead of the fax?
In windows Vista or 7:
  • Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  • Right-click the printer you want to use, and then click Set as Default Printer. A check mark is displayed on the printer icon to mark it as your default printer.
  • In windows XP:
    • Open Printers and Faxes; click Start, click Control Panel, click Printers and Other Hardware, and then click Printers and Faxes.
    • Right-click the printer you want to use as the default printer, and then click Set as Default Printer. A check mark appears next to the printer icon in Printers and Faxes.
    Hope this helps!
    Mar 17, 2011 | Serif Computers & Internet
    Whenever some tries to call me while using my DSL,
    It sounds as if your PC's fax/modem card is set to automatically receive faxes, so the PC answers the phone whenever it's on. To fix this, you need to set your fax modem to receive manually (or disabled if you don't use it to receive faxes). Open the Printer and Faxes (Windows XP) and double click the fax icon. If this is the first time you've opened it, you'll have to go through the fax configuration wizard, if not, you'll be presented the Fax Console. Click on Tools, Configure Fax. On the second page of the configuration wizard, you'll be presented with the select fax device. This is the page where you select to enable fax sending and receiving. Turn off the Enable Receive check box if you never want to receive faxes. Leave it on, but set to manual if you want to be able to manually receive faxes (every time your phone rings, you'll have a notification in the system tray asking if you want to receive a fax).
    Jan 30, 2010 | Computers & Internet
    Can't fax
    check the cable has been put into the corect connector on the back it has to be put in the socket marked line.. if you have it in the other one for tel the fax cant hook up..Good Luck A
    Jul 31, 2009 | Brother IntelliFax-2820 Laser Fax
    I can send fax but cant recieve fax
    You have not told us which model fax you have but most machines have a receive mode selection. Your machine may be set to 'manual' receive. It will only receive if you pick up the phone and hit the start buton. The phone has to be connected to the machine. Look on your machine for the receive button. It may be marked as 'auto receive' and 'manual receive'. Select 'auto' so the machine will answer. It may be marked as 'fax mode' and 'tel mode' if so select 'fax mode''. It may also have a selection 'ans mode' you don't want this as it assumes that you have an answer phone connected to your machine and it waits until the machine answers before it detects incoming fax. Good Luck
    Jul 07, 2009 | Brother IntelliFax-4100e Fax
    Fax machine won't answer and pickup. I have to manually pick up the receiver and press start. This just started a few days ago.
    You probably have it in the fax/tel or TAD mode. Press the butoon on the top right side of the keyboard marked "mode" until the light above it is on "fax" only. This mode (fax/tel) is for phones/faxes hooked to an answering machine. The "fax" mode puts in into the direct answer mode as a fax machine.
    May 22, 2009 | Brother IntelliFAX 4100 Laser Fax
    Black marks only when faxing
    check the Scan glass where you put the original to fax, there should be a door to open and see a small strip of glass, clean it.
    Nov 17, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
    HP OfficeJet 9110 - Receive Fax Error 223
    HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
    1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
    2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    3. Enter the parameter ____ on the key board and press the Check Mark.
      • 159 - Receiving Fax baud rate
      • 153 - Transmitting Fax baud rate
      The screen will read Cfg param val: 26
    4. Enter in the value ____ and then press the Check Mark .
      • 0 = V.17 14400
      • 2 = V.17 9600
      • 6 = V.29 9600
      • 10 = V.27 2400
      Screen will read Test -001+
    5. Press the Reset button until you get back to Ready *
    Mar 04, 2008 | HP Officejet 9110 All-In-One InkJet...
    Change baud rate
    Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Dec 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
    Fax connection
    Turn off distinicive ring option (menu 0 something)
    plug in direct to phone line on connector marked line, put telephone into docket on fax marked EXT.
    Nov 15, 2007 | Brother MFC-3240C All-In-One InkJet...
    Lexmark X4270 All-In-One InkJet Printer Logo
    20 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
