Ran a Modem Diagnostic Test.. Says I am not connected, but i am connected to the interent... what is wrong here? Just Curious...
  • Trish
    Trish Nov 19, 2008
    hey after searching and searching for answers i stumble upon this , it's interesting because i have this exact problem. I connect to the internet using a satellite connection and it automatically assigns an ip by DHCP. quite often i find myself disconnected and when i check the connection properties it displays as if it is still connected and such but it says incorrect ip address. I cannot figure out for the life of me what is the problem , usually 1 or 2 reboots will correct this but it happens so frequently it is very annoying. My connection on another computer is strong and steady , that one being hardwired ,so i know it is not a problem with my provider. I tried the ipconfig at prompt and the correct gateway shows so this did not help me , if anyone has any suggestions please help me get a clue 8)
  • 78 Answers
Don't worry about that.. these are some internal tests run by the modem.... which are sometimes inappropriate.... as long as you are conected dont worry about them... right. happy surfing...
was i helpful?
Posted on Nov 19, 2008
No interent connection
Your Linksys wireless router needs to be connected to a DSL or cable modem which needs to configured with the settings that your Internet Service Provider gave you.
To test your Internet connection connect a LAN cable fron your conputer to the DSL/cable modem. If you cannot connect to the Internet using this methos, you need to contact your ISP and the can check the connection to your DSL/cable modem.
Apr 12, 2012 | Linksys Computers & Internet
My computer will not go on the inter net after i ran the restore disk
you might have to set up your intenet connection again which will mean setting up your modem/router again
hope this helps
Dec 13, 2010 | Dell CACHE CARD ETHER-PCI+/CT Sound Card
Inter net browser opens but doesn't connect, internet connection is connected but cant connect to the browser? I'm using either Firefox or IE on a dell 8300 that had a vundo problem. since I ran a clean up...
this is typical, there's a new virus that overwrites the dns server details and the only fix for this problem is either to waste hours recovering dns or doing a clean installation will fix it. "clean installation means format the hard drive, and re-install your operating system"
please rate me.
Mar 07, 2009 | Dell Dimension 8300 PC Desktop
Linksys router
Connect modem to internet port of the router and computer to any numbered ethernet port.
Feb 19, 2009 | Linksys Computers & Internet
Unable to connect to internet
well !! according to me you've got a programming problem in your modem due to electricity fluctuation so , to solve this check if u hv a user manual of your modem ... if u have then its really good...
u will find a re-programming isp code ...
now to solve this first switch your modem on then go to any browser and type in the isp code there which is somewhat like " 192.168.1.1 " etc.
type that in the address bar and click enter ..
find the reboot option in the menu and click it..
your modem will reboot and then your internet will start working again !!
now just connect to internet via your default connection ....
your problem is solved....
Oct 30, 2008 | Dell Computers & Internet
Need help w/ethernet connection
do this go to start >> then run , type >> inetwiz << then tell it to connect using my local area network , tell it to automatically discovery of proxy , then click next, no to setup email address, "you can do later if want to" then click finish and reboot computer
then try opening internet explorer , make sure if you have a firewall "you have to allow access to internet when asked "
Let me know if that got you fixed or not
Nov 23, 2007 | Insignia D400a PC Desktop
2wire modem not broadcasting wireless signal
are the lights on the modem detecting any connection? is your line still programmed for broadband? if your modem is connected at the phone exchange and the connection is at your house and all and none of your computers can connect to the net, not even the primary computer and you have called your technical team for broadband (can be company policy sometimes to call them) you may need a replacement modem. Tech support should do a ping and other tech things to try to get you connected. you may have a faulty modem which if it is new then you should be entitled to a warranty replacement. if it is a simple setting on your computer they should be able to resolve this, i know that when vista first came out there were a lot of support issues with bband providers being able to support the users.
Nov 22, 2007 | 2wire (1000-000057-000) Modem
Wireless router
first connect the devices in this way
from us inter net modem to belkin routers inter net port connect a ether net cable rj45-->then connect another ether net cable rj45 from pc to -->ethernet port on teh belkin router>and reboot the router and modem if u r using cable inter net then immediatly that will work>and open a browser window type this in address bar http://192.168.2.1 u can see the belkin login screen and follow this link
http://www.gorge.net/help/wizard/belkin/f5d7230-4_pppoe.htm
rate me solved if its helps
Nov 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
