Question about Frigidaire Ovens
Bake & Warm drawer on Frididaire oven takes forever to heat.
We purchased a Frigidaire oven in the spring of 2007 (Model GLGFM96FPBB). The lower oven simply does not heat up timely, nor is the temperature accurate when it does finally heat up. It takes approximately 45 minutes to heat up to a temperature that's somewhat close to 350 degrees. It's been like this since we had the oven delivered. Is there some switch or something that needs to be turned on in the back in order to get the dumb thing to work right? Thanks for your help!
Where is the speed bake switch located on a Frigidaire oven
Hello friend, thank you for your post!
Based off the information you have provided you need to know the location of the speed bake switch inside of your Frigidaire oven. I would be happy to provide you with that information, if you can provide me with your model number. You can locate the model number on the serial tag and that can be found on the bottom drawer frame. Once I have that information I would be able to assist you further. -Matt
Dec 13, 2015 | Frigidaire Ovens
NEED BAKE ELEMENT FOR THIS MODEL
Hey friend, thanks for your post!
I understand that you are in need of a bake element for your Frigidaire wall oven, RGB94K. I would recommend performing an online search for antique appliances to see if any additional parts are available for purchase. I hope this information has been helpful. -Matt
Sep 27, 2014 | Frigidaire 24" Single Gas Wall Oven with...
Oven taking too long too bake.
If you still have your Frigidaire Oven there is an reason why it take longer to bake. Frigidaire Oven has an safety limit control inside the oven and it is place on top of your oven. We know that the heat go up,so that control is cutting the heat will the thermostat is asking for heat.I had a Frigidaire oven, I change 2 control a the end a purchase a new one. When I scrap the old one I notice that problem,
Jan 18, 2014 | Frigidare Ovens
Lower bake element is not working on frigidaire oven
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Mar 04, 2011 | Frigidaire PLEB30S8A Electric Single Oven
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
Oven takes 20 minutes to fully heat on bake - Kenmore oven plt095-2
if its a gas model most of the time you will have a weak oven ignitor. if an electric,check to see if the bake element gets hot ,some ovens will bake with upper and lower elements so if only the upper works it will take much longer to pre-heat.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 16, 2010 | Kenmore Ovens
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
52 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
