Question about Refrigerators
E249T Fisher and Paykel Beeps when door opened
The Fridge seems to be working fine however it now beeps 3 times every time door is opened
  • Norah McKinnon Nov 16, 2012
    freezes everything in fridge
Disconnect the Fridge for 5 mins. After that, should be ok.
Posted on Apr 12, 2009
  • paulmcdow638
    paulmcdow638 Sep 01, 2012
    Brilliant worked like a charm. Thank you very much.
With mine the dairy section cover was not switching off the interior light. Used iphone on video to confirm light was not going off when door closed. I Propped the dairy cover up a bit so it hit the button better.
Posted on Mar 22, 2012
Our fridge bleeps every time the door is opened and now the freezer is not working
Hi Ruth,
If you are seeking assistance, may I suggest you provide more information about your fridge, like brand and model number.
If it was a Fisher & Paykel, and it was beeping, count the number of beeps. This will indicate the fault code. Report back with that information
Dec 02, 2016 | Refrigerators
My fisher paykel model number# rf170adx4, serial # rhg755331 fridge beeps every time we open the door (not leaving it open)! It's a brand new fridge.
It is probably just a warning beep to let you know the door is open. It should stop when the door is closed. There may be an override setting to cancel this. Have a look in the Owners book to see if you can reset this or check with your F and P Customer service centre and ask.
Nov 19, 2016 | Fisher Refrigerators
How do I fix the continuous beeping coming from my refrigerator?
LG Fridge Door Alarm ' Chris Inch
www.chrisinch.com/blog/articles/show/lg-fridge-door-alarm/
Aug 30, 2006 - It's just too bad I can't live with beeping noises going off every 30 seconds. .... took them a long time and they scratched the paint) the fridge beganbeeping ..... I opened the fridge door to let the alarm sound and then located the alarm..... I can't tell you how many times I've "snapped" since hearing this thing.
FIXED Frigidaire Professional Constant Beeping - ApplianceBlog
www.applianceblog.com/.../17546-Frigidaire-Professional-Constant-Bee...
Jan 15, 2010 - 10 posts - ‎3 authors
The refrigerator is not refrigerating and I don't here the fan go on or ... the water comes out from the water dispenser and so does the ice. ... Thank You so much! ... The unit is two years old from time of purchase. ... Then to install it you remove the #81 screws here: 11-Controls parts .... All times are GMT -6.
Fisher & Paykel fridge in alarm - Kitchen - Home - Whirlpool
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolJan 24, 2010 - I push the selector button to mute the alarm and then it may not do it again ... I can determine the fault code through the number of beeps/flashes? ... myfridge started beeping every 6 hours abut a week ago. ... posted 2012-Aug-7, 3:17 pm.... If so, defrost the coils behind freezer, you can use a hair dryer to ...
Feb 03, 2016 | Refrigerators
Why did door alarm suddenly start going off every time I open the fridge or freezer?
Hi Christine.
When your F&P beeps, it's indicating a fault code - count the beeps which will relate to a fault code. 17 beeps would indicate an issue with the freezer fan.
Could be the reed switch (door switch).. amount of beeps will indicate the fault code.
Dec 14, 2015 | Fisher and Paykel E402BRXFDU Bottom...
The door alarm of my fisher and Paykel E372B fridge goes off when the door hasnt been opened for a number of hours. How can I stop this.
You would notice that when it beeps, there are a series of beeps, which relate to an error code - also, the temperature panel would be most likely flashing the same amount of times the beeping occurs. The code relates to a component failure that the active smart system is having problems with.
For example, 17 beeps would be error code 17 - which relates to the freezer fan is drawing less current than is expected. Either the wiring is open circuit or the fan is faulty.
Feb 18, 2015 | Fisher and Paykel Refrigerators
Fridge beeps every time door is open
Seems like a damper issue unless you have dual evaporators.
Apr 14, 2013 | Fisher and Paykel Refrigerators
My fridge beeps intermittanly
Hello, when a fisher and paykel is beeping it is usually beeping due to a door being open or ajar or the switch that interacts with the door closeing being at fault. First check your seals and assure you have no rips or tears in the seal. Secondly you would check the switch that the door closes against usually the small black strip on some of there models. If you need me to bring up your schematic to show where your switch is located message me back your model number of the machine. Also if you have any further questions message me back those as well. Another question for you is if you look on the rear wall of the freezer do you have any frost built up if you did this would be called a defrost issue that your unit was having. Most of the time though the beeping sound is due to the switch for the door shorting and after it does short tells the control that the door is open. I await your reply if you have any further questions and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks,
Rick
Aug 23, 2011 | Fisher and Paykel Refrigerators
Refridgerator E249T the beeping alarm wont stop. The door appears okay. How can I disconnect the alarm, please? Thanks Brian
I have the same fridge. It was driving me crazy. I emptied it. Cleaned it. Defrosted it. And was ready to dump it. Then worked it out. As it beeps when the door is open. How does it know. Because when the door is open the light is on. I taped up the light nob with masking tape, on top left of fridge. No light now
But no beep Yay!!!!
Jun 14, 2010 | Fisher and Paykel Fisher Paykel DD24DCB6...
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Refrigerators Logo
1,193 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
